I wish my apartment had at least a covered car port.
I've had my 33 in the elements since I got it a few weeks back...
...and at work there is nothing.
It's not so much the rain as the UV. So I feel bad about it.
My car is in pretty good nick compared to many of the 33's I seen about and I would like to keep it that way.
I've got a car cover now but feel (and look) like a douche putting it on and off and it's a lot of effort. :)
Bad things happen indoors!!
Haha nah, I have a covered carport, and a garage thats apparently big enough for one car, I doubt it and its always been full of too much shit to throw the Ceffy in there. I use my car as storage, and the shed to store shit like bumpers, dash, fender, that are all out at the moment. More concerened about people stealing my shit, not exactly easy to find some things. Would be nice to be able to use the garage, means less time finding tools and work light each night, packing up, means Im not under pressure to have shit back on the car before I go to bed either, I can just lock the door and know its safe.
I'd guess putting a cover on it would make it more appealing to people wanting to boost shit?
Ha ha that's true.
I remember a few years ago a buddy of mine - who owned an Aston martin and a e-type jag - went away to work overseas and on returning found a shelf in his garage had collapsed and put some dents in the jag. lol
Anyway my parking area is secure, its not like it's on the street.
We've got a big f**koff shade sail out the back. a double car port won't work on account of the fact we've got 9 cars in the same drive way.
proper garage goes to *gasp* a BA GT! *continues sob story* well, that car belonged to my uncle may he rest in peace, and so sayeth his will that his sister my mother received his house AND car. And, since it hasn't been driven in two months, a deep sadness within compels me to steal it. and drive it. then put it back.
yes mine spends all day every day out in the elements i used to have schmicko paint work now my bonnet has little or no clear left all peeling off..
what ya gonna do
i no shannons wont insure unless its in a garage
maybe by a portable tent thing.. put that up
My car cover blew off last night...quite embarrassing. Now it's secured with two ropes.
The R33 is slightly too big for the medium sized cover and way too small for the large cover. So with the medium sized cover 'cos it's not stretched over the car 100%, a bit of wind will get under it and dislodge it on one end, then the whole thing slides off. :ninja:
Need to get a flat with a car port or buy a proper house with a garage etc.
See lots of bunky looking cars around Perth damaged by UV. Don't want my car being like that.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
