Im buying a house next year with my partner and one of our main requirements is that it has a garage!!!
At my current house theres a car port but i can never park my car in it.
And i live in boddington at the mine camp most the time anyway so i just bought a car cover for it to protect it from evil gold dust
ModYourCar have a car cover that doesn't touch the car I think...lemme see if I can find the linky I saw before...
http://www.modyourcar.com.au/touchless-car-cover-p6931
there ya go...seems quite expensive though, not sure how sturdy it is in a strong breeze.
just read it, says it's usually for indoor use, so maybe no go unless you can secure it.
There are so many faults with the above car cover.
It says doesn't touch the car but it touches the car when putting it on and taking it off so it will scratch the car if any dirt is on the car. The cover also touches the ground and rests on the ground when he is folding it up which will then get transferred onto the cover and then onto the car and scratch it when putting it on/taking it off.
My car lives outside but I got a car cover made specifically for it which is fully weather resistant and really soft on the inside for only $220, went through the whole winter and car was not affected at all by moisture, wind or anything.
P.s - still sucks to have the car outside but not for long as moving to a new place with 3 car garage so 32 can go indoors and rendering my car cover useless.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
