Hi i know this might be already covered. But i just purchased an innovate lc-1 wideband sensor and xd-16 guage kit for my car but wat i also want to do is be able to connect it to the fc datalogit but am unsure of how to connect it to the datalogit box as i dont have the manual for the datalogit. will i need to purchase any other parts. this is what i have. http://www.innovatemotorsports.com/xcart/p...at=0&page=1 and also this http://www.innovatemotorsports.com/xcart/p...=262&page=2 Thanks in advance.
https://www.sau.com.au/forums/topic/291999-fc-datalogit-and-wideband/
brown lc1 wire to an 1 on the datalogit box.
go to inovate there is instructions specific to the datalogit there.
edit: here's the link http://www.innovatemotorsports.com/resourc...fc_tutorial.php
Edited by URAS
and before you start tuning with it make sure the reading on the datalogit is the same as the reading on the gauge (or logworks program if you dont have a gauge). i had a lot of troubles getting myne to read the same and none of the wiring methods on the net worked. gotta play around with the grounds a fair bit
    • RBF660 doesn't meet DOT5.1 as it is too thick. DOT5.1 has a very low viscosity requirement compared to DOT3 or 4. (Dot5.1 must be half as "thick" as DOT4)   It would also be a big indicator for anyone using that fluid in extremely cold weather to possibly look to swap for something in the DOT5.1 range.
    • Here is as close as we got to a direct comparison(3 vs 4inch exhaust), a tickle more boost, which I am sure was in part due to the exhaust.  Made 790 on more boost.
    • Next minute, carbon fibre boot 😂
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
