Hey i was wondering if anyone has made a custom air feed for the standard airbox? I got a front mount where the piping goes around to the front near the radiator and the standard air guide does not fit. Any suggestions would be great. Car is an r33 gts-t by the way.
Cheers
https://www.sau.com.au/forums/topic/292024-custom-air-feed-to-standard-airbox/
most people just trim a bit of the snorkel so it clears the piping
problem with the 33's is the top half of the box is the air feed, so you need to tap into that to be able to run a custom CAI on the std box.
Check out the Custom Fibreglass Enclosed Airbox And Snorkel For Gt-t, Ghetto Gruppe M thread in this section (http://www.skylinesaustralia.com/forums/Custom-Fibreglass-Enclose-t261635.html).
It has a few ideas in there. Any fabrication work you end up doing might not actually improve much over the standard snorkle if you're restricted by room. The standard snorkle is actually pretty restrictive. You may be better off spending a little money on getting the I/C piping to return to stock I/C piping locations. You can then do a snorkle mod and get more beneift from it do to the extra room and less restriction.
Thanks for the ideas guys. Only reason i want to keep the standard airbox is because my car will have close to 300kw and i do not want a cop to even think about sending me to a epa test. So i really cant go with a custom box as it will arouse some sort of suspision, i was also thinking or re-routing the intercooler pipe to go over the top of the engine to use the standard air guide and to do a home job of porting it myself to make it as wide as possible.
Craved, yea i know its a problem that the air must enter from the top of the airbox, would be so much easier if you could just go in from the bottom. Ill try to speak to my mechanic and see if he has any ideas.
If you don't want any suspicion from the police then don't wash it much/paint your car silver and don't make it stand out :P
I haven't installed my custom snorkle/airbox lid yet as I still a few things to change. But I have increased the size of the inlet to the lid and internal cross section of the snorkle. If you make your piping run behind/underneath your I/C and back to the standard piping it is going to stand out much less than any non-standard looknig piping running over the engine. You can then use a larger custom snorkle etc to cover some other things slightly it you're concerned.
If my setup doesn't provide a great gain then I still have the option of changing the lower section. In standard form the AFM is set quite a long way into the box. This blocks off a lot of potential area of the filter. Mounting it further back will free up this filter area. The inlet pipe will need to be altered also so it would take a bit of stuffing around. This would only be needed though if there is no major drop off in boost/power high in the rev range. If it doesn't drop off then it should mean it's flowing well enough not to be an issue.
http://plazmaman.com/shop/index.php?action...m&itemId=13
I inquired a while ago and they were willing to just sell the pipe from the tb to the inner gaurd, i ended up buying a blitz return flow fmic instead.
  • 1 month later...
does that actually work ?
It would work if you have a filter on the end of the pipe and you are not using the standard piping set up going through the gaurds, the same set up used with fmic's to avoid cutting holes in your inner gaurd to route the piping over the engine.
  • 3 weeks later...
  • 3 weeks later...
Doesn't the R31 have the filter below the afm? maby someone could make it fit the R33. then could use that hole from the factory cooler pipe as a cai, while still looking stock.
negative, same set up as a 33
Fit a pod on the air intake pipe inside the stock airbox, then cut a hole in the airbox and run some piping from the airbox to somewhere down the front. It's cheap to do and retains that factory look if you don't look too hard.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
