hey guys picked up my r33 yesterday and has a mad hesitation not only on boost but even down low, when accelerating it hesitates, then power comes in then hesitates once again.
today i changed the fuel filter finding the filter itself inside the housing was rattling around. it made it slightly better.
the car has a large bosch fuel pump in it and the next stage it to replace that.
if anyone has had anything similar in the past i would like to hear about it.
Thanks, Paul
https://www.sau.com.au/forums/topic/292026-hesitation-on-acceleration/
Im having the same problem in the 32, from the research ive done it could be a) the AFM(s) if so give them a clean, b) the spark plugs, if so grab some new ones c) coilpacks, silicone them up or replace them or d) 02 sensor, this is a bitch to check but ive decided to bite the bullet and get them replaced for peace of mind. Im installing new plugs and coils today, well let you know how it goes. In the mean time theres a sticky'd 02 sensor section or go here http://www.skylinesaustralia.com/forums/Mi...sensor+problems for the other ideas ( he had a 33 gtst aswell)
Edited by CGB_R32
It's not the f#$%^n O2 sensor - its input is totally disregarded by the ECU during acceleration!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! How many F$%^&*N times does it have to be said!!!!!!!!!!!
[/rant]
Now, I know you've only had the car for 1 day, but what mods does it have? Aftermarket ECU? Atmo BOV? Anything else?
thanks for the help,
umm its got forged pistons, cams, big garret turbo, full exhaust with extractors, full motec, front mount, bov, upgraded fuel system, upgraded ignition system, rims, all whiteline suspension + more i cant think of.
[/rant]
i'm guessing quite a lot more times yet, LOL
i'd start with the simple things like plugs and work your way from there.
i had something similar with my SR 180 when i first bought it. tried everything, ended up being the fuel pump.
what plugs are you running, maybe you need something hotter... had some shitty hestitation when i swapped engines in the 180, swap from plat plugs to copper ones fixed that. worth a shot at $3 each :D
[/rant]
I stand corrected.........................wacked in the new spitfires and plugs and yay no hesitation any more!
im running iridium plugs, and they look near new. coils are good too not arcing around edges.
im a mechanic so i have run fuel pressure tests to eliminate the fuel system.
i have also quenched the cam sensor and that made no difference
took out plugs and coils today to check them, put it back in and didnt seem as bad, took longer then usual for it to start stuffing up i think i might fill the plugs with a grease to see if that fixes it.
yea the thing is its running full motec and i highly doubt that will shit itself. i have to get a cable for the motec to plug a laptop in and see hte problem,
again this avro will b more diagnosing and ill see how i go, thanks for the help so far guys
I thought oxygen sensors remained in use (closed loop) until wide open throttle, i.e. until the throttle position sensor is maxed out it's still going to be used?
did abit more work today, tomorrow i am putting my mates r33 coils in my car and seeing how it runs. hopefully better.
gota do a few little things like change belts, service, brake fluid flush ect, and polish it too so its a big weekend for me!
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
