hey guys picked up my r33 yesterday and has a mad hesitation not only on boost but even down low, when accelerating it hesitates, then power comes in then hesitates once again.
today i changed the fuel filter finding the filter itself inside the housing was rattling around. it made it slightly better.
the car has a large bosch fuel pump in it and the next stage it to replace that.
if anyone has had anything similar in the past i would like to hear about it.
Thanks, Paul
https://www.sau.com.au/forums/topic/292026-hesitation-on-acceleration/
Im having the same problem in the 32, from the research ive done it could be a) the AFM(s) if so give them a clean, b) the spark plugs, if so grab some new ones c) coilpacks, silicone them up or replace them or d) 02 sensor, this is a bitch to check but ive decided to bite the bullet and get them replaced for peace of mind. Im installing new plugs and coils today, well let you know how it goes. In the mean time theres a sticky'd 02 sensor section or go here http://www.skylinesaustralia.com/forums/Mi...sensor+problems for the other ideas ( he had a 33 gtst aswell)
Edited by CGB_R32
It's not the f#$%^n O2 sensor - its input is totally disregarded by the ECU during acceleration!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! How many F$%^&*N times does it have to be said!!!!!!!!!!!
[/rant]
Now, I know you've only had the car for 1 day, but what mods does it have? Aftermarket ECU? Atmo BOV? Anything else?
thanks for the help,
umm its got forged pistons, cams, big garret turbo, full exhaust with extractors, full motec, front mount, bov, upgraded fuel system, upgraded ignition system, rims, all whiteline suspension + more i cant think of.
[/rant]
i'm guessing quite a lot more times yet, LOL
i'd start with the simple things like plugs and work your way from there.
i had something similar with my SR 180 when i first bought it. tried everything, ended up being the fuel pump.
what plugs are you running, maybe you need something hotter... had some shitty hestitation when i swapped engines in the 180, swap from plat plugs to copper ones fixed that. worth a shot at $3 each :D
[/rant]
I stand corrected.........................wacked in the new spitfires and plugs and yay no hesitation any more!
im running iridium plugs, and they look near new. coils are good too not arcing around edges.
im a mechanic so i have run fuel pressure tests to eliminate the fuel system.
i have also quenched the cam sensor and that made no difference
took out plugs and coils today to check them, put it back in and didnt seem as bad, took longer then usual for it to start stuffing up i think i might fill the plugs with a grease to see if that fixes it.
yea the thing is its running full motec and i highly doubt that will shit itself. i have to get a cable for the motec to plug a laptop in and see hte problem,
again this avro will b more diagnosing and ill see how i go, thanks for the help so far guys
I thought oxygen sensors remained in use (closed loop) until wide open throttle, i.e. until the throttle position sensor is maxed out it's still going to be used?
did abit more work today, tomorrow i am putting my mates r33 coils in my car and seeing how it runs. hopefully better.
gota do a few little things like change belts, service, brake fluid flush ect, and polish it too so its a big weekend for me!
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
