Second Hand Tyres - Never Pay For New Tyres Again.
HEKT1K - 2 reasons to be honest, 1 is because i want to lower the car abit more, 2 because 235 tyres are alot easier to come by as i work at vw.
hamish - haha funny you say that, as i work on burwood road close to tyrepower, im good mates with mickey, sami, loc. got my wheels from there also.
and about the legality issue, well my car has a high mount setup on it now, and the wheels stick out the guards (18x10 +22) so i think ill be screwed over for other stuff anyway. (no this doesnt mean that i dont care about any law lol)
which vw, camberwell?
But hang on, you guys arent mentioning anything about PROFILES, when that is the second most important thing when stretching tyres...
Bas, the guys at T.P Hawthorn chucked on some 225/45s on my 9.5 rims fairly easily, took them a few goes but they got them on, 235s wouldnt be a drama on a 10 as long as you use 45 profile. They have the equipment down there to blow the tyre onto the bead.
I want to try a set of 215/45 on the 9.5 next time lol.
i can see the benefit for a roady maybe, but i just booked in for Traction Tyres to fit/balance a set of Kumho KU36's, 245/40/18, $1k. Fair bit less if i wanted to stretch some 235's on (much more common size) but they said for a 18 x 9 rim, with track work, no less than 245. So that's what i did
although, if i was JUST driving on the street, i probably would consider some second hand ones. But Ash is spot on though, if they've seen quite a few heat cycles, the tread could be great but the compound has just gone to shit (a bit like my $$ bridgestones are now) and makes the tyres worse than a set of Lin Longs or something
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
