Second Hand Tyres - Never Pay For New Tyres Again.
HEKT1K - 2 reasons to be honest, 1 is because i want to lower the car abit more, 2 because 235 tyres are alot easier to come by as i work at vw.
hamish - haha funny you say that, as i work on burwood road close to tyrepower, im good mates with mickey, sami, loc. got my wheels from there also.
and about the legality issue, well my car has a high mount setup on it now, and the wheels stick out the guards (18x10 +22) so i think ill be screwed over for other stuff anyway. (no this doesnt mean that i dont care about any law lol)
which vw, camberwell?
But hang on, you guys arent mentioning anything about PROFILES, when that is the second most important thing when stretching tyres...
Bas, the guys at T.P Hawthorn chucked on some 225/45s on my 9.5 rims fairly easily, took them a few goes but they got them on, 235s wouldnt be a drama on a 10 as long as you use 45 profile. They have the equipment down there to blow the tyre onto the bead.
I want to try a set of 215/45 on the 9.5 next time lol.
i can see the benefit for a roady maybe, but i just booked in for Traction Tyres to fit/balance a set of Kumho KU36's, 245/40/18, $1k. Fair bit less if i wanted to stretch some 235's on (much more common size) but they said for a 18 x 9 rim, with track work, no less than 245. So that's what i did
although, if i was JUST driving on the street, i probably would consider some second hand ones. But Ash is spot on though, if they've seen quite a few heat cycles, the tread could be great but the compound has just gone to shit (a bit like my $$ bridgestones are now) and makes the tyres worse than a set of Lin Longs or something
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
