This is the updated version of the famous VQ30DET. This is not the same as the 300ZX VG30DETT.
Its basically a VQ30DE out of the V35 skyline, with oil squirters, lower compression and a turbo thats very similar to an R34 GTT turbine. Quoted at 206kw and strong as hell these engines are perfect for a drift set-up or a perfect candidate for engine transplant into a skyline or Silvia.
I was driving my Y34 cedric with this engine for a few weeks until the transmission blew up, so I garantee the engine is in great condition. It comes complete with loom and ECU, but NOT including a transmission.
It also comes with the Y34 subframe including steering rack and suspension, so you might even be able to make that fit.
Contact Ben on 0417 366 372 or email me at [email protected]
some specs on the engine pulled from here => R34 VQ30DETT Conversion
VQ30DET
Manufacturer: Nissan
Type :
V-6 DOHC
24 valves total
4 valves per cylinder
Bore × stroke
93.00mm × 73.30mm
3.66 in × 2.89 in
Bore/Stroke ratio 1.27
Displacement
2987 cc
(182.278 cu in)
Unitary capacity 497.83 cc/cylinder
Compression ratio 9.00:1
Fuel system EFi
Aspiration Turbo
Intercooled
Max. output
(JIS) 269.7 PS (266.0 bhp) (198.4 kW)
@6000 rpm
Max. torque
(JIS) 368.0 Nm (271 lbft) (37.5 kgm)
@3600 rpm
Specific output
89.1 bhp/litre
1.46 bhp/cu in
Specific torque
123.2 Nm/litre
  • 1 month later...
  • 1 month later...
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
