I have a Blitz SBC ID Spec R boost controller and am missing the teflon line that gets teed from a vacuum line into the control unit (i am assuming this is for the map sensor). Does anyone know where I get buy some replacement line from?
I have been trying to work out a way to join the teflon line from the back of the control unit to normal silicone hose. Will this work?
Any help appreciated.
Edited by Deano45
how does it connect to the "teflon joint" in the picture? if it simply pushes on the you could just get some vacuum hose from autobarn or somewhere like though.
The line pushes inside the teflon joint, so normal vacuum line wont fit.
I'll try to post up some more pictures tonight when I get home.
Should be able to get some autometer branded line from any auto parts store. WIll cost under $10 iirc.
Just take the EBC in there and the T piece to make sure you get the correct OD.
I have the same EBC, good choice :D
Cheers
-Jez
I have the same EBC, good choice :whistling:
Cheers
-Jez
Thanks for the tip, I'll check it out
If you're really stuck i've got a spare length left over from trimming it- i'm in bris but will post it no probs. Can also make little barbed fittings for you if you need to modify fitting it up. PM if needed.
Andrew
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
