  • Replies 76
what engine i can pull up some runs for you. I have heard mixed results on reliabilty but thats the case with everything i suppose. I think ive had 3 or 4 through two on sr's and they were pretty good for top end power but i remmber the sr20 one with gtk550 made 380rwkw but hit boost at 5800 or something stupid....
Wow, 5800 is a bit rich! If you wouldn't mind posting some up Trent it would be greatly appreciated.
It's would be on a SR22 with 90mm bore and 272/11.5 cams, 0.5/1mm oversized valves and CPC 1 piece plenum.
I think the T in GTK might be worth a closer look at the turbine and compressor wheels , T series stuff is getting a little long in the tooth for many true petrol performance apps .
I would have thought that something from the Garrett GT ball bearing range would be better for a two litre four - even a big bore one .
What sort of power are you looking to crank out of your engine ?
A .
That is the way I'm leaning at the moment, but it was just a thought that crossed my mind and I'm interested in finding out about all options prior to making a decision.
At the moment the main contender is a Twin scroll 3071R/3076R kit, T67 8cm or a Tial housed 3071/6 on a steam pipe manifold. The car is a circuit car, so I'm looking for a wide power band and potential to make at least 300rwkw's (have to make it worth my while going from the HKS T300 on it now).
Dane
I think you could throw a TDO6 L2 in the list of potential turbos too for your power output.
Although I do like the twin scroll turbo setups as they exhibit a more linear power curve than some turbo seups which will potentially result in a faster circuit car.
You don't reckon 300Kw is a bit much from a 2L based four for track ? I'd be concerned that the power would be peaky and the usable rev range a bit narrow for most circuits .
Not cheap but have you considered a GT2835 Pro S turbo ? The cropped GT30 turbine is fine as long as its in a GT30 based turbine housing which unfortunately only HKS make . Actually if you could rat up a T3 flanged Po S turbine housing the cartridge HKS uses can be bought through Garrett and on a four cylinder it shouldn't surge so possibly don't need HKS's compressor housing either .
Anyway your call but you need to have power out of the slowest parts of the track as as wide a usable rev range as possible . Also peaky short power ranges force you to use expensive close ratio gear sets to stay on the boil .
Controllable usable power you can get to the ground , better I think than a high peak number .
Cheers A .
Also you call but I wouldn't use anything less than the early head and the GTiR quad throttles , throttle response and least restriction throttling is everything for track .
Tets: Thanks, will see how I go mate.
Disco: Thanks for the tips. I'm not necessarily after 300rwkw's straight up, but to be honest with the money I've spent on this car I want to have a window to increase power to a level that makes the build worth my while. I was running 240rwkw's for years on the stock engine, and I don't believe a 20-30rwkw gain is not enough for me to bother changing setups. At the moment it's ramping up to power in the mid 3's, and so long as I have a 3500rpm band of power that's fine. I'd prefer a 4000rpm window ideally. I do know what you mean though, and on my current turbo setup with the stock bottom end I was caught between gears at Winton quite a lot.
I'm going to be trying my T300 out initially to see how it goes (hasn't had a full tune yet due to a few issues), but if I'm unhappy with it I want to move quite quickly on a new setup to take advantage of the good state of our dollar. Throttle response with the CPC plenum and 80mm TB seems fine for the moment, and it's an S13 head. Throttle response is the main reason I'm thinking of going the Full race twin scroll setup.
To help understand my thinking, the reason I'm contemplating this prior to tuning the current setup is because my HKS SS manifold can't take the heat of the track, and has cracked a few times. Therefore I need to purchase a new steam pipe manifold, and don't want to do this for a setup that I may want to change shortly. So best for me to work it out and only purchase what I really want, as I've spent money on turbo setups over the years!
Thanks for the 2835 suggestion too. The Pro S is internally gates isn't it?
Disco, the Evo that took out the last Super Lap had something like 550rwhp - OK I realise its 4wd - but who would of thought a TO4Z strapped to an Evo motor would be a force on a circuit and actually bettered Mark Berry's new R34 by about a second from memory .....ahh yes the EVO had a Full-Race twin scroll manifold tho'.
Also Dane's is stroked to 2.2.
Edited by juggernaut1
i was going to get a gtk. but through hours of searching on the net in the us, i didnt get one.
seems the fancy comp housing and relativly small exhaust housings are a restriction,
something in the reigon of 60-65mm inducer will do.
its either garrett or borg-warner/bullseye
ive had a thrust bearing go on a tdo6 not sure how much stronger the l2 version is but.
Thanks Dave.
Full race are going to be testing out the Borgwarner twin scroll turbo's soon enough I think, which is another option right at the top of my list. Just not sure when the results will be available though, but may be worth the wait from what I'm told.
Yeah I read the GT35 vs BW the other day and it's pretty promising. They're also a fair whack cheaper than the Garret stuff, and seem to work as well if not better in a lot of cases.
This is the turbo that might be looking like a bit of a winner according to Full Race:
L2 is good for 300rwkw on a track weapon no worries at about 20psi.
Here is the GTK550 @ 25psi (this is the only graph i have on this computer) this is about 40rwkw shy of its potential because the fuel system was not adequate so i had to dumb it down. I reckon its the worst turbo i've seen on a sr to date :devil: but on a rb26/30 id be happy.
Edited by URAS
L2 graphs on 2 liter, only ran it to 7300 as engine was only a hour old and the box was noisy (std sr box0, should make power to 8200.
18psi 272deg cams big lift, engine built by us.
We should be able to crank up the boost in the next few weeks, i predict 340-355rwkw ish at 1.5 on pulp.
Edited by URAS
L2 on std SR20 with HKS 264 in and ex, std valve springs, ikeya formula 4 tb plenum.
300rwkw on a fairly "fat" tune (less timing and 11.8afr) as engine was std. i would expect to see another 20rwkw easy in that car at the same boost, cams were a bit small too.. and springs were borderline rpm wise.
Edited by URAS
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
