I'm suprised not to have found the answers on a search but this is what I need to know:
Pitfalls of a second hand purchase? (if any)
Brands / manufacturers - which ones are good?
Where to buy, if new?
What is important in a good adj. cam gear? What to look for.
Don't want to go over the top and nor do I want to buy crap.
Thanks.
https://www.sau.com.au/forums/topic/292082-adjustable-cam-gears-rb26/
I wouldn't buy them second hand unless you can inspect them, particularly the condition of the teeth first, and make sure you stay away from the old version HKS gears which were notorious for tooth wear which led to timing belts slipping - not something you want!
If you have the money, Tomei and HKS both make their new version gears from Duralumin and are the pick of the bunch.
For something a little more budget friendly, get yourself a set of OS Giken gears, they are a fair bit cheaper than both Tomei and HKS and I have never come across anyone who has had an issue with them :whistling:
Perfect. Just the advice I was looking for. Best places to buy from? Being honest I suspect I'll go with Ash's option but be good to look into this too. Cheers.
Stock gears can be modded and made adjustable.
Considering you can't see them behind the cam cover - cheapest option that works the same as stuff double the price
Thanks Ash. Given the std items are decade(s) old, they still OK to modify? Is it a case of good old quality Datto items? Also, where can I get them modified and do you have a rough cost estimate.
Should be ~$150 to have the stock ones fab'd into adjustable if memory serves me correct.
They are as strong as anything else, so no issue.
Thx. Where from? Who will do that kind of work? Cheers.
anyone had experience with the jjr product?
i've got ones similar(probably the same) as the jjr product...
they are ok but the bolts are shithouse, so i went and got a set of stainless steel bolts from local fastner place, worked a treat
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
