R32 Gtst Dash Cluster Plastic Surround + Center Vents
Hello,
I am looking for a replacement R32 dash surround and the center air vents.
Regards
Johnny
Thanks for the Pm's guys .. I would reply but I apparently have to have 10 posts before I can :(
Just clarifying - I need the plastic that is around the gauges (speedo / tacho etc) which also includes the lights / wiper switches.
Thanks
Johnny
depends if you want a gtr or gtst dash surround
forgive my ignorance but what are the differences between the two, and will a gtr dash surround fit into my gtst ?
Thanks
Would you be interested in a GTR dash cluster aswell to go with the surround? $100 perfect working order only 71,000 genuine kms...
pretty sure, we have already Pm'd you, but we have a dash cluster surround and center vent in pristine condition, the surround is from a r32 gts4 and the center vent is from a 32 gtr... PM us if your keen
I'll take it, I will give you a call tomorrow or Friday to organize. :)
Regards
Johnny
Hey Sebastion , I am 2 posts away from being able to reply to pm's (SAU rules : 10 posts to reply)
Thanks anyway but as above I have found a dash + surround for $100
Regards
Johnny
  • 4 weeks later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
