aye guys if u want to, i dunno just a thought, if you got a N/A Skyline, post up a p[ic of ure car and bout the price you would sell it for, just to give some idea to some people how much it wuld cost for a skyline and what value for money they culd get
just a thought, dun have to if u dun want to, its kinda like show and tell, only with more expensive toys...
thanks
https://www.sau.com.au/forums/topic/29217-na-pics-and-prices/
I'd sell for $13k providing I'm in a frameset to sell. I'd sell for any offer above $14k with little hesitation. My justification is that its a 1993 R32, and is actually the last of the R32 GTS's that came in under the old SEVs. Its modified with mandrel bent extractors, and all sorts of GTR goodies n accessories, light up skyline panel, factory equipped with all the late model S Spec (equivalent of M Spec for turbos) trim and mouldings, stabiliser bars, suspension and air con, factory CD stacker etc.
And it does 87rwkw in 3rd gear and 76rwkw in 4th gear on the BMT dyno (in comparison an R33 GTS with same mods did 82rwkw in 4th gear on the same dyno).
Well i got a 92mdl R32 GTS25, got full stereo and catback exhaust, 17" mags, and a panel filter(big whoop) dont know what i would sell it for, gotta get some slight panel damage repaired but after that prolly part with it for 13k or so.........pretty rare combination of the r32 and rb25de.......but i aint parting with it, i got some plans for my baby...........one day
Wouldn't sell my one at all at the moment....as it's heading to turboville, and the money has started to flow into it already:)
It's a 1999 25GT, with Dark Blue Pearl paint & GReddy E-manage....turbo currently sitting on the garage floor :D
Dan
same gettin either a t04e or a td06 (depending on if I get it at auctions in japan) on an RB25DET engine :D So does any1 wanna buy a shmick RB20DE with mandrel bent fujitsubo stainless steel extractors and 2.5" stainless steel exhaust?
No pics sorry... i aint got one. Its very straight, bodywork is almost immaculate, interior is MINT CONDITION. Paintwork is unfaded Wine Red. Speedy Club Line 2 mags. (for memory thats what they called).
Type "M" Bodykit (ie. standard 95 model kit incl. spoiler on 93 model)
1993 R33 GTS, 70,000kms would sell for about 18g'z
mostly stock, adjustable racing suspension (it can get bloody hard as hell). Takes corners like no other. But im not quite ready to sell my car as i only just got her and wanna do mods to it etc etc.
Thats a reason why i would sell it for 18g, cus i wouldnt really wanna sell at this stage.
sorry its in photoshop.
MOds
Coby Extractors
ROH Blades 235/45/17
Blitz Airbox Filter
Gtr Body Kit (Don't like the front bar)
High Def Light Bulbs
Undercar Neons - Red
Pioneer Headunit
6x9 Speakers
Razo Pedals
Cannonball Muffler
Illegal Tint (Can't see when i turn corners, have to look out the windscreen)
THats it
give up on the supercharging... i looked into it and even with habib rates n a lot of favours it costs just as much to put a turbo engine and a big f**koff turbo on it (which is what I'm doing).
1994 R33 GTS-4
50,000 on the clock
Got it just under $19,000 in 2000 I think...
came with whole lot extras like, ACCESS ECU, front and rear struts, ALEC lowered suspensions, Bridgeston new tires, Blitz filters, arrhh yeah its 4WD...
it was cheapest GTS I could find @ the time...
added Wheels, REDLINE oils gears.
enjoy.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
