Hi
I planned to buy R32 GTR, but still cannot decide between import or buy it second hand.
I know the advantage and disadvantage of both method.
In carpoint.com.au, I saw some decent R32 GTR can be bought on $19.000 to $21.000 in Adelaide.
But the problem is, I cannot find the car with the condition that i wanted (good for everyday use and clean interior)
I felt maybe import can be a good choice for me.
So my question is
- Is it possible to get R32 GTR to be imported into Australia? (I heard 15 years old car rules change and i don't know the new rule)
- Is it true total cost of import can be cheaper than second hand? (under $20.000 for R32 GTR maybe?)
- I am finding Gunmetal grey or white R32, is it difficult to find in Japan?
Thanks anyway for taking your time ^^
https://www.sau.com.au/forums/topic/292179-import-or-local-second-hand/
People usually import only if they are after a rare or limited model of car, contrary to common belief that you can save money buying from japan, you actually pay a premium for good condition vehicles in japan - you pay peanuts, you get monkeys.
If you're simply after a clean standard GTR, try look locally, interstate etc,
If you're after an exquisite N1 or V-spec II then i would be worth it to scout in Japan - There is a very good importer in Adelaide, Kristian who runs Iron Chef Imports, he is a member on here aswell and would be very happy to answer any of your questions. His website is: http://www.ironchefimports.com/site/
Pics don't hurt either =P
Do-luck R32
Happy hunting =)
Hey Omega,
Just for your info, when we are importing cars there are 2 models we pay particularily close attention too, RX7's and R32Gtrs, because condition is very very important. For a R32 Gtr you could get one in as low as $13K but they will be in bad shape, but for $20 you can get one in Top condition exactly the way you want it. We also recomend you stick to late 92 - 94 models because of the intrusion bars and also cause they will be better condition but it is easy enough to get one in. Our benefit is we do both the import and the compliance if that helps. Drop me a line if you have anymore questions,
Regards
Paul @ Carizma
Hi
So my question is
Hey David,
Sorry to steal the thread but just one question from me...what's the landed and complied price range on an FD RX7 these days? I.e. poor condition low price and top condition high price?
I'll pay ya later Danny lol
I agree with Paul though - better to spend the money on a nice low-km late model R32 GT-R. Getting earlier, rough ones can be a bit of a false economy, because you often end up spending lots of cash just keeping it on the road once it's here. $18-20K will get you something nice.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
