Hi Guys
Im now tuning my PFC and trying to work out the Optimum VTC setting for R34GTT with a slightly laggy T04E turbo. To compensate the low rpm load before the turbo get spooling at fullboost around 4k rpm, can i set the VTC like 3500 rpm and will it do any damages if it were set that low? Still stock cams but with adjustable cam gears for exhaust side only (slightly retard settings).
https://www.sau.com.au/forums/topic/292181-optimum-vtc-setting-for-r34gtt-neo/
Hi Guys
Run the car up on the dyno with the VCT off then with it on, note the rpm at which the dyno graph cross over and set it at that - you could run full advance till the rev limiter and not cause damage.
Today i tried setting at 4000rpm for road tuning (since i hv wideband), car felt very lively and more spirited in town driving. Felt like VTEC effect especially when downshifting or upshifting the rpm will just drop on the sweetspot.
Just wondering whether VTC helps more on low or high load? Would consumption suffer at the setting im running now?
Not planning on doing any dyno runs atm, until i upgrade injectors and cams.
Edited by driftmeister
Make sure to do several dyno runs, one at 25,50,75 and 100% throttle and note the cross over points, put the change over at the mid point of all 4 cross overs.
Another option is to set up a 2 dimensional VCT activation mode, eg TPS (throttle position) and RPM to get he maximum effect. I do not know if PFCs allow you to create custom 2D maps from two inputs to control an output though.
Certainly be interesting to know your results if you do do this though.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
