Hi Guys,
I was hoping you could give me some advice regarding my 1993 Nissan Skyline R33 GTS-T.
The problem I am having is quite difficult to explain. I'll be driving along normally with the throttle open and then all of a sudden the revs will drop and the engine will cut out. It's like the throttle just cuts out. I can have my foot flat to the floor and the revs just drop and the engine cuts out.
But, if I then turn the ignition off and restart the car, it will continue on driving normally until of course, it happens again!
This happens every trip I make in the car without fail. It generally happens after I go over a large bump, or when I change gears. It has also ocurred twice when I have activated my windscreen washers. It also tends to happen more often when the car is cold, or has been driven hard for the first time in the course of the trip.
It also has a tendency to happen when the car is at idle-albeit less frequently.
The car also has a tendency to hit flat spots and hesitate at high revs (above 4000).
I have had the car dyno-tuned twice and the plugs replaced in an attempt to solve the problem. The car also has a new clutch. But, the problem began to occur before the clutch was replaced. Other mods on the car include a turbo-timer, short shift gearbox and sports exhaust.
It has been suggested to me that it could either be an airflow problem, or, a problem with the ignition regulator/modulator, but, the mechanic I have been taking the car to has so far been unable to fix the problem. Obviously I am not too happy with this and was also hoping you could recommend a reputable mechanic/workshop in Melbourne that specialises in or at least has a great deal of experience with R33 Skylines.
From my limited knowledge of cars, I feel it is probably an electrical fault or fuel injection problem, but, I really don't know. This problem is very frustrating and also very embarrassing when it happens in the middle of an intersection-not to mention dangerous.
Any advice you could offer me on this issue would be greatly appreciated.
https://www.sau.com.au/forums/topic/2922-r33-gts-t-skyline/
Baby Zilla - 2 Things
1. Add your Location in your profile (We know you're in Melbourne Now!! LOL!)
2. I know a couple of places that will be able to fix your prob without ripping you off. Theres 3 Places I know of in Dandenong
and one near Knox area.
Let me know if I can be of service to you.
Sam
https://www.sau.com.au/forums/topic/2922-r33-gts-t-skyline/#findComment-51259
Originally posted by OOHSAM
We had the same prob (TPS - Throttle Position Switch) with one of our ZX's, I was told that this only hapens in Auto Cars.
I dont think it have to do with gearbox... if something wrong with some sensor I think it would stuff up ur car no matter what gearbox you have.... n lucky my '93 R33 auto has been driving beautifully so far... zero mechanical problems....
https://www.sau.com.au/forums/topic/2922-r33-gts-t-skyline/#findComment-51487
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
