Hi,
At a dyno day I noticed that a R33 Series II GTS25t produced a much more linear power curve than my Series I. A performance workshop has told me that this is entirely normal, and it's because the Series II ECU is superior.
Is it reasonably easy to install a Series II ECU into a Series I?
Thanks,
Greg.
https://www.sau.com.au/forums/topic/29222-series-ii-ecu-into-a-series-i/
Hrmm. I believe it would be very easy but if you are trying to replace the stock ECU with another stock ECU I have heard that the 1995 model is the pick of the bunch.
I think the money it would take to find a 1995 ECU would be better put into getting a PowerFC.
The ECU itself is very simple to pull out, you can find it behind the passenger side kick panel.
I cannot verify this with any emperical data, it is purely anecdotal, but it has "better" maps.
I believe there were some posts here once with some graphs representing the maps from 95 ECU's and other year stock ECU's. I will use the search button now.
Fair enough i was unaware that the VVT was the same on all RB25DET until much later models. Thus my question has been answered and i will shut up...
Hehe dont shutup, its a good question and I have no proof to back myself up so either of us could be right.
On topic, I agree that as an "upgrade" the 95 ECU is only worthwhile if you can get it for free or swap over your existing 93, 94 ECU. It is well overrated.
i think you guys may be mistaken ... from what i've read and heard i think the reason why 95 is better is that the ecu takes to mods better ... i've heard of disaster stories with mods and early r33's ... in that the power was less with the mods ... but the 95s take it better ... but nowhere as good as a powerfc :) ... thats just what i think .
Thanks for the info everyone. My car is a '95 model but I haven't checked my ECU yet. I do recall the workshop being surprised at the power gain after installing a 3" turbo back, high-flow cat and pod filter - it went from 121kW up to 147kW, however they said the timing had to be pushed back a fair bit as well. (they said that it appeared to have been tuned for the Japanese fuel)
I now have 168kW @10.5psi - nothing wrong with my maximum power, but it would be nice to have the nice linear power delivery that I remember seeing on the Series 2 dyno plot. I have an EBC which has helped to bring on the power earlier (by eliminating the two level boost staging which the factory boost controller produces), but it still doesn't look as linear as I remember the Series 2 being.
Just for kicks, is anyone able to post a Series 2 (in stock form, or close to) dyno plot?
Greg.
i think you guys may be mistaken ... from what i've read and heard i think the reason why 95 is better is that the ecu takes to mods better ... i've heard of disaster stories with mods and early r33's ... in that the power was less with the mods ... but the 95s take it better ... but nowhere as good as a powerfc  :D  ... thats just what i think .
Yes. In 1995 they included magical abilities into the ECU. Each one is factory blessed by a registered fairy and sat upon by a japanese school girl before being excreted into the car at high velocity by a small leprichaun with a big butt.
This makes about as much sense as your post with about as much logic to back it up.
I tested a few different ECUs this week and found none any better than the others but Tomei ECUs have about 10% less power acoss the rev range but no speed cut and a lot higher rev limit.Boost was the same the fuel was good by jap standards but the timing was soft.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
