hi all,
this forum has been a great helped to me doing things yourself, i just did oil change, oil filter, fuel filter myself the other day thru the tutorial and guidelines here in SAU :banana::banana: , now im about to do my gearbox oil change and diff. oil change as well, as its been 85k's now on the odo. (but could be more knowing its an import car) but could not find the link or tuto. here :(:unsure: ....been searching for the last 2 days and it doesnt show how to do it for R34 NEO DET engine, only the previous car model... :devil::glare:
please some help here...just show me the link and ill be good... :P
and some link how to install walbro pump 255 lhp for ER34 too, if u could... :happy:
cheers guys... :thanks:
i needed more details tho...the one in the tutorial with r33, it doesnt helped me much...
i need to know where the gearbox plug located and the fill plug as well, as i am a newbie with this kinda stuff..
is the gearbox plug next to the sump plug or somewhere else located??
is it visible enough if u go underneath the engine with the cover on?? or cover off?? i mention these becoz when i did my oil change, i didnt have to take the cover off...
so needs more details...please help...
what sort of gearbox oil should i use and diff. oil...
cheers
R33 exact same gearbox. The gearbox drain plug iirc is visible on the drivers side halfway between the front and rear wheels (ie. nowhere near the fricken oil drain plug or engine under cover).
As for what fluid to use, read the transmission oil sticky in the Drivetrain section.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
