Thinking of selling my Silvia
It "was" a factory 4 cyliner turbo
Now its got the 6 cyl r32 rb20det motor with 5 speed
New billet extreemly light flywheel (thought I got posted an empty box from japan)
New extreem 6 puk brass button clutch and 800kg pressure plate
R32 gtr 4 spot callipers up front (5 stud)
R32 single piston calipers on rear (5 stud)
30mm bolt on wheel spacers front/rear
16x8 wheels with 225/50 tyres (front new) (rear 50%)
Previously owned by a lady who travelled a total of 100,000km
Motor runs sweet, its a low km jap import
Kenwood stereo with 10 stacker in boot
3 inch mandrel bent exhaust from turbo back
Still running factory intercooler
Currently car is unregistered
It's not complied with engine conversion or brakes yet
Although has import tag and has still got rego plates from being 4 cyl.
Make me some offers may look at swaps etc
Prefer cash as misses is giving me a son for xmas lol
Phone 0448 199 167 or pm etc
See pics below
Cheers Chad
https://www.sau.com.au/forums/topic/292232-fs-s13-silvia-sa/
Car is located in north eastern suburbs of adelaide
Currently engine is stock spec except clutch and flywheel
to pass regency , so stock turbo and ecu
Also just fitted r33 wheels as other wheels wouldnt pass with spacers
front tyres new , rears 60%
  • 3 weeks later...
  • 1 month later...
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
