Well, as i have posted in the transmission forum, i killed the stock gearbox, i went for a par 1-4 S/C syncro box.
This thread is a quick outline of what i got for the money and where i got to down the strip. Car is a low km R33 GT-R V-spec with a really big guy driving it!(Read fatty lol)
1: Par 1-4 S/C sync G/box. $5745
2: 600cc Nismo drop in injectors and nismo upgrade fuel pump (second hand albiet in good working order) $920
3: Vi-Pec Plug in ECU(the one that fits into the stock ecu box, internal 2.5 bar map) $1650
4: Tune (god this was hard to organise in a regional area) $475
5: Hi-Flowed standard Turbochargers( these were only 70k old so i figured rebuild to -5 specs) $1600
6: Adjustable cam gears $499
7: Random spares(ie. vac. hose, gaskets, general consumables) $300
Stockish run(up-pipes and 3.5" exhaust, K&N panel filter) stock boost ect. 12.58
Next up when the box arrives ill start adding power mods and the box and keep you all updated :(
Any suggestions ect please, keep it clean and constructive!! Im all ears, im an ex subaru nutcase so GT-R's are a new field to me!
https://www.sau.com.au/forums/topic/292262-the-10g-gtr-thread/
Next up when the box arrives ill start adding power mods and the box and keep you all updated :D
be interested to know how they work out
Well, the turbo's are off, the box is out and on its way to the builder and my hands look like they have been through a god dam mincer, OHMAGAWD the turbo's are a bitch of a thing to get out, im dreading the installation process something fierce! Now, the Vi-Pec goes in! See u all in an hour or 2! :cool:
just a word of advice with the ### gear sets get that box in there as quick as you can and make shaw it is good i got one of there gear sets in my r33 gtr and it was far from good when i put it back in wouldnt hold gears had heaps of problems getting fixed as it was out of waranty after i got my car back on the road in the end i ended up taking it to another work shop and got it rebuilt to make it right cost me an extra 1000 on top to get right just be careful
Quick update guys. Nismo Fuel pump is in, Injectors are in, did new front brakes and rotors while i was at it (thanks QFM!) new TPS and im currently getting the exhaust manifolds port matched to the head and turbines, there pretty messy from stock. Now, do i do the dumps or are the 33 dumps good enough? Just that the turbo's are off and ill be fracked if i wanna do that again!
Cheers, Allan
Updates!!
Recieved the gearbox today!
Injectors in
Fuel pump in
Vi-Pec in
Cam gears in
Gearbox *shudder* waiting.
Now i have gone a little over budget here guys. After a good hard chat with a few people and forecasting the possibility of future modifications i have decided to buy a new set of -5's. I was told standard turbo's could be modded to -5 specs, but as its been pointed out, rear housings are different. They can be modded to make near similar power as a dash 5 but geez you would be flogging the batshit outta them. The Bill so far!
Gearbox: $5745
Vi-Pec: $1650
Pump and Injectors: $920
Turbochargers: $2450
100k Service kit: $420
TPS: $120
Gasket Kit: $240
Consumables: $300
HKS Dumps: $280
Total so far: $11705.00
Still to come: Tune up, AFM deletion pipes, Intercooler Hard Pipe Kit. It seems 10g just wasnt enough!! If only i didnt have to do a box!
So, at the end of the day, im hoping to get away with approx 13k to get where i want to go. One day ill figure out how to post god dam photos on the intrawebs and ill show you all something you have all seen before, a GTR in pieces!!
People to thank so far: Jim Berry, Andrew Sullivan aka Kudos Motorsports, Dori34, Ray Hall Turbocharging, PAR engineering, Just Jap Racing and my wife who now hates me, baaaaad.
PS> any ideas for AFM deletion pipes?? the cheap way, im pretty handy with steel :P
Cheers, Allan
  • 3 years later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
