Dude, pull your f**ken head in.
If you got a problem with anyone here, then its >your< problem. You don't speak for me, and I quite like Dan's posts. You have no right to tell people what they can and cannot post. We have mods for that reason, and they haven't said anything... why? Because you're the only one getting the tampon in a twist. Next time you got an issue, bite your tongue and you won't look like an emo dickwad without a sense of humor.
-D
yeh whateva
i guess i shouldve bit my tongue and not said anything but there was no need to write all that crap that he did when it had nothing to do with the topic of the post
i just wish people would stay on topic, if u want to post irrelevant dribble then thats what the WASTELAND is for!!!
oh damn now im not on topic
Edited by ovrtym33
looks like blood pressure is more of a problem than oil pressure here :) i think sau as a whole need to work on expressing their opinions without taking shots and overuse of the f word to the point it lost all meaning
on the topic of dodgy dials in skylines my fuel gauge just died on me, was showing funny readings for a while untill today it just completley dropped off the charts to well and truley below Empty. filled it up to see if that would change it but no :)
Edited by Inline 6
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
