I dont think it would be totally unreasonable, but you will have to do a bit of work to get it there - port, match the manifold, cams, etc - there are so many variables. If you are thinking of getting the 3037 new, I would suggest buying it in kit form, as you will save alot of money. The kits come complete with all the bits you need to fit them (well 99%).
By comparison, I picked up my turbo cheap (new), my wastegate cheap (second hand), and with all the other bits, manifolds, gaskets dump etc, I could have just bought a new HKS full kit for the same price and saved myself months of stuffing around, plus I would have had a package of parts designed to work together.
  • Replies 86
yeh ill have a hks style top mount manifold
and i have all the required lines etc left over from a hks 2535
ill invest in some cam gears, might help us move the powerband around a bit
also whats the go with the dump pipe on these turbos
they look to have a different design at the rear compared to a normal t3 style
Regards
Dylan
Regards
Dylan
btw the turbo im after is the new internal wastegate style if that makes a difference
hey all
im coming in a little late i now, for that im sorry
im looking to purchase and install a new HKS 3037PRO s with internal gate and .87 rear end
im really hoping for gull booost by around 4000-4500 rpm on an rb20det
other modifications will be power fc, gtr injectors, and obvious support systems (fmic exhuast etc)
i just wanna know...am i dreaming??
thanks in advance
I would use the .69 exhaust a/r with the rb20.
.87 is quite large when you consider the vg30bb turbo is a .81 and makes 1bar by 4000rpm.
Remember it is a 480hp turbo so you will definately have to fiddle with cams etc to get boost in where you want it. Just bolting the turbo on I think it would be on the opposite side of 5500rpm for 1bar+.
Any 1 had any experience with 500hp turbo's that make a genuine 300rwkw on the RB20's?
Someone lend me a Trust TD06-25G or T67-25G (DJ_L3ThAL :D ) and im willing to give it a go on my grenade. I saw a T67 turbo off a CA18 i thought about it, but then i realised i havent even got my TD06-20G setup working 100% yet :Oops: .
He-he, hello again Sydneykid.
I am sure the cams and all the pulleys are manufactured extremely accurately, so the stock cam timing SHOULD be spot on, but it never is.
The problem is the cam belt.
There will always be some permanent stretch in an old belt, and even a new belt is going to stretch a bit as you tension up the adjuster. Now the adjuster is on the slack side, so as you take up a bit of extra belt length on the slack side, this will retard both cams with respect to the crank. And it does not take much stretch to shift the timing by rather a lot.
Think about it. One full turn of the cam is 720 Crankshaft degrees, and the cam pulley has 48 teeth. That is 15 crank degrees per tooth.  The belt pitch is 8mm per tooth.
There is a fairly long length of belt between the crank and the exhaust cam (not sure exactly how much) and if it stretches only 4mm, that would retard both cams by a huge 7.5 degrees.
So you might have a situation where you have four different dead stock engines, but the individual cam timings all over the place by a few degrees because of different belt ages, different non Nissan belts being fitted, and different belt tension settings. And what about head gasket thickness..... ?
So everyone retards their exhaust cam by exactly four degrees. Two guys get a power increase :D) one guy says it makes no difference :0/  and the fourth guy gets a slight power drop :)(   I wonder why ?
And why do Nissan bother to make the cam position sensor adjustable if the cam position can NEVER vary away from stock?
I prefer to set my cams up using a degree wheel and check the exact opening and closing points with a dial indicator on the cam followers. Adjustable cam pulleys allow you to always put it back to what it was when you did that really fantastic dyno run. If you do not do this, in reality you have no clue where those cams actually are, and after a major rebuild there is no chance it will go back together exactly the same.
I just believe there is no substitute for measuring and checking things, and if anything is going to change, that very hard working rubber timing belt should be treated with the greatest suspicion.
If you really heave down on the belt tension adjustment, you can actually see both cams move slightly !......... Try it and see.
While I am sure YOU do all this, a lot of guys just fit the variable pulleys, and back off the exxhaust cam from the marked line, not bothering to actually measure anything. All they really care about is the dyno figure.
Sorry, I still don’t understand why you would bother spending all that time setting up the camshafts perfectly to the standard timing (the “old “way) and then the first thing you do is stuff it up by changing it on the dyno. I see nothing wrong in moving the camshaft timing around to get the power curve you want, be it a higher max power or a better power curve for your purposes. I really don’t care what the timing was BEFORE I started, I only care where it is AFTER I tune it. I mark that with a timing light on the crank pulley and record it on the dyno sheet. This works by maintaining the relationship between the CAS and the camshaft pulley.
As for duplicating it after a rebuild or when the belt stretches, that’s too easy. I just reset the camshaft timing with the timing light by adjusting the camshaft pulleys (not by changing the relationship between the CAS and the pulley). There is so little cambelt length between the inlet and exhaust cams, the stretch there is truly miniscule. If I want to be precise, I mark the position of the camshafts themselves with a pin punch when the crank pulley is at TDC. So I don’t really give a shoot about cylinder head machining or belt stretch.
By doing it this I can put the camshaft timing back exactly where I tuned it to be, easily and quickly. Plus I can check it in the car with the timing light. If I use the “old” method, I have to start all over again, set up the standard timing, then stick it on the dyno and tune it. That seems like a big waste of time and money to me.
What I hope to achieve with this post is to educate people so that some may actually do it, so I see no reason in teaching them the “old” way. The ones that want to learn, might as well learn the “new” way.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
