other than all the obvious bs and my dislike for the look of wrx's the major question is what are you gunna do with it?
the gtr is a bigger stronger and heavier car that can seriously move while the wrx is a nimble Fing little thing that can do some serous cornering (tho id rather an evo)
me id pay off a serious chunk of the mortgage but ive got a track car in the shed so
  • Replies 79
if it has to be a 4 door, 2.0L, smallish car
FIXED, besides, some Cefiro's came in AWD too, if traction is what you want.
Please die! :)
Lets face it, apart from the GTR in mention, there are way too many R33s running around...theyre becoming the Commodore - something different?
No, IMO its no longer an import if you can walk out your front door and go find one in a non HPV car yard.
Reckon this guy is starting to get the feeling that the WRX isnt liked around here much ?
Yeah I know it LOOKS like that...it's just that we 33 owners drive around ALOT (because our cars are just SO great) so it just LOOKS like there are more 33's about than there really are. :)
Anyway at least it means parts are forthcoming etc.
BTW I see WAY more Imprezas about. Now they are common.
Does that mean Commodores are the greatest car ever? seing as there are more of them than any other car on the road ? :) no, it means theyre cheap, and for knuckleheads.
Hahah, just kidding. I dont exactly hate the R33, I just think theyre the least appealing, and too many of them...I reckon Japan would take some back if we offered.
So, you're comparing a NON-STI to... not only a GTR but a GTR V Spec...that make the battle even more unfair. Disregarding such obvious advantages is like being stubborn and insisting your Civic runs 11 seconds without NoS...only in the movies buddy :(
Other pro's / cons:
Probably just as cheap to insure and run the GTR
Better response from 6 cylinders, and displacement
AWD system is much better
You'll probably find more support (and social acceptance) for the GTR on forums
EDIT:
Of course, this is all assuming you want power and performance, not hair gel and nasal delivery....
Edited by Nic_A31
Yeah I know it LOOKS like that...it's just that we 33 owners drive around ALOT (because our cars are just SO great) so it just LOOKS like there are more 33's about than there really are. :D
true... i see shit loads of imprezas on the road.. and i drive around alot.... they are nothing special..
i think the OP should have got his answer by now...
4cyl 2.0L single turbo vs 6cyl 2.6L twin turbo
id pick the gtr .. its got more power...looks better... and u dont have to like it in the bum to own one.
To everyone saying WRX's are slow, did anyone see [GTR ETA] at powercruise? Because im sorry to say, but that was owning everything until it got engine knocks...
That said, WRX's are still gay and the GTR wins hands down :D
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
