HELLO,
HAVE BITZ AND PIECES I FOUND IN THE SHED AND WOULD LIKE A NEW HOME.
IM LOCATED IN BRISBANE SOUTHSIDE,I CAN POST/COURIER ANYTHING AT BUYERS EXPENCE OR COME PICK THEM UP!
NOT ON THE NET MUCH SO PREFER PHONE ENQUIRIES. 0438-167-207
PICS OF EVERY SINGLE PART LISTED HERE ARE UP!
1-R33 GTR SERIES 3 REAR SEAT EXELENT COND WITH RED STITCHING,NO CIGGY BURNS OR GRUBBY MARKS-$375
2-GTR RB26 (32,33,34) GENUINE GREEDY PLENUM.WAS USED ON 1 OF THE WILLAL RACE GTR'S IT HAS 100mm INLET INSTEAD OF THE 90mm INLET THAT STANDARD GTR PLENUM'S HAVE.COMES WITH LINKAGES ETC -$850
3-R33 GTR NISMO 320KLM DASH CLUSTER SHOWING 20,000KLMS NEAR NEW- $525
4-R32 GTR VEILSIDE 340KLM (YES 340KLM..THATS FAST..) CLUSTER SHOWING 77,OOOKLMS- $475
5-RB26 ROCKER COVERS WITH POLISHED FRONT TIMING COVER- $350
6-GTR HKS STRENGTHENED ACTUATORS X2 - $350
7-R33 GTR COMPLETE UNDER BONNET WIRING HARNESS ECU HARNESS,INJECTOR HARNESS,ENGINE HARNESS (NEW THESE ARE VERY EXP FROM NISSAN) THE LOT $1,200
8-R33 GTR TAILSHAFT $400??
9-R33 GTR COMPLETE PEDAL ASSLEMBY $250
10-R33 GTR 4WD PUMP $450
11-R33 GTR BONNET CABLE $80
12-R33 GTR FACTORY SIDE SKIRTS QM1 COLOUR (WHITE) $400
13-R32 GTR SIDESKIRTS $250
14-RB26 GTR N1 ENGINE ENGINE BLOCK BORED OUT TO 87mm COMES WITH THE N1 CRADLE,NO CRACKS WORKED FINE JUST STRIPPED ENGINE AND NO NEED FOR IT ANYMORE (I DONT HAVE THE PISTONS THAT CAME OUT OF IT) BLOCK & CRADLE $650
15-R33 GTR/GTS-T SAFETY 21 7 POINT ROLL CAGE ONLY DONE 1,500KLMS HARD TO GET 33 CAGES! COMES WITH PLATES AND ALL PADDING, BOXED AND READY TO SHIP $950
16-R33 GTR TURBOS I THINK THEY STANDARD (PART NUMBERS INDICATE THEY ARE) WERE WORKING FINE 1 A LITTLE STIFF MAY FREE UP ONCE RUNNING COME WITH ACTUATORS ETC THEY OFF A 1997 V SPEC $300
PLS PREFER PHONE ENQUIRES 0438-167-207.THANX
HELLO,
Hi, Corey
Just spoke to you,will work out a package with Attessa pump,N1 block,roll cage and Plenum, and GTR33 320km cluster
cheers
Alex 0439818008, 0433 878905
ALL PM'S REPLIED TO.
EVERTHING STILL AVAILABLE.
555KKK HAS MADE A DEPOSIT ON N1 BLOCK BUT DOESN'T SEEM TO RESPOND TO CALLS...PLS ADVISE?
TIM GTR-ALL OTHER PARTS STILL AVAILABLE ON YOUR "PARTS REQUEST LIST"
IT'S ALL UP FOR GRABS!
UPDATE ON WOTZ STILL AVAILABLE...
NISMO CLUSTER------SOLD
N1 BLOCK-------SOLD
EVERYTHING ELSE STILL AVAILABLE!
GREEDY PLENUM FOR RB26 ANYONE? WILL DO FOR $800 DELIVERED!
PLS PREFER PHONE ENQUIRIES 0438-167-207 CHEERS.
would you post these to townsville 4815? if you will i'll take them
do they come with the centre piece?
i would call but overseas at the moment.
cheers
rob
Edited by robbo_rb180
cheers
rob
yes rob i will post.sorry i dont have the centre cover.
your wife called the other day and said she would make the deposit? havent seen it yet....did u still want them?
i cant pm as i have used all my pm's up for the day.
NEED THIS STUFF GONE....
^is this still for sale? and ca it be used as a half cage? cant tell from the pics..
Cheers
Johno
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
