im confused, and i think you are as well.
the PFC will have an existing tune on it which you can erase by the hand controller or by datalogit
ETC, DATA INIT, YES, Reboot Car, Default maps are now loaded
or
plug in datalogit, Read All, Save the file to your PC in case you need it and then Menu, Initialise, reboot car, default maps now loaded
either of these will get the car working and drivable to a tuner
remember if you data init / initialise (either way) to perform self idle adjustment before driving the car (covered in the PFC FAQ)
also be sure to note if car has aftermarket AFMs, map sensors or injectors to note down their settings before DATA INIT / Initialise
https://www.sau.com.au/forums/topic/292325-datalogit-file/#findComment-4885241
hijacking it up but has any ever had any trouble copying datalogit map and log files. i've been using a vista laptop and the only way i can open the files outside datalogit is to use the datalogit open screen and create a shortcut on the desktop, cant copy them like this tho. using windows explorer the files simply arent there. have checked and they're not hidden. any gay protection setting in datalogit?
https://www.sau.com.au/forums/topic/292325-datalogit-file/#findComment-4886614
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
