Up for grabs is a nicely modded 1997 Nissan RS-Four V Stagea. I am the first owner of this car in Australia and has been a pleasure to own but needs to go to make way for a new car!
Car has always been serviced every 5,000kms with a fully synthetic oil, run on 98 octane, and has only been boosted to 11psi which it made a safe 129.4awkw (can provide dyno sheet) with a slipping auto and been told it has heaps more in it but needs a copgy back ecu to get it to close to 200awkw on the standard turbo.
Since then car has had nearly 3k spent on the transmission which was rebuilt with Kevlar bands, heavy duty clutches, valve body modified for more solid shifts and stall flushed which was done by GZM Automotive. Also replaced the rear tyre's less than 6 months ago, replaced the alternator and installed 6" Apline Type S splits.
Spec's are:
RB25DET
94,000kms
All Wheel Drive
Reg to mid next year (June 2010)
FMIC
Spitfire Coil Packs
Turbotech Boost Controoler
Apexi Air Intake
HKS Boot Guage
3" Exhuast from the turbo back
Rebuilt Auto
18" Blitz Type 03 Wheels
Blitz Engine & Trans Coolers with Braided Lines
7" Double Din DVD Player with MP3/USB/Bluetooth
Freeway Dolphin/Nismo bodykit
Alpine Type S 6" Speakers
Twin Sunroofs
Nismo Clear Indicators
Con's:
Font bumper has a few crack's but can be easily replaced from between $400-$600 if your really picky from various body kit specialists (can provide quotes)
Please contact me on 0412 876 885 with any inquires
Edited by SHIZNT
https://www.sau.com.au/forums/topic/292343-fsvic-nissan-stagea-rs-four-v-11000/
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
