JDM TYPE X 180 Collectible
The car is in mint condition, both physically and mechanically A1. You will not find a 180sx in this condition, with the mods on it. Never had any accidents, completely straight. Legitimate reason for sale, need money for house. This car is not for the faint hearted. It holds a safe tune of 190kw with great handling mods. Just the mods alone cost more than the car. I am a car enthusiast, so the car looked after very well. Here's the list of mods. Grab yourself a bargain. Enjoy.
-70,000km
-1996 Blacktop SR20DET
Mods:
- S15 injectors
- HKS air filter
- Hybrid Intercooler
- HKS GTSS turbo
- Apexi Power FC+controller
- Nismo fuel regulator
- Cusco catch can
- HKS oil cooler
- Hybrid electronic boost controller
- Cusco air diversion plate
- Nismo engine cap
- Nismo radiator cap
- Nismo power brace
- Nismo gear knob
- front and rear strut brace
- front and rear sway bars
- Cusco castor rods
- Cusco camber arms
- Buddy Club P1 17x8 front, 17x9 rear
- Bridgestone RE001 all around
- Defi gauges x 5 (water temp, boost, exhaust temp, oil pressure, oil temp)
- Defi controller
- Pivot shift light
- Pivot lazy eye controller
- Teins Flex with EDFC
- Apexi RSM (black)
- Bride brix ii x 2
- Apexi turbo timer
- Fujitsubo full exhaust (dump,front pipe, high flow cat, cutback)
- 5 stud conversion (s15 front brakes , r33 rear brakes)
- Cusco brake stopper
- Exedy heavy duty clutch
- GP sports bodykit
- Carbon fibre rear centre garnish
- Sony USB headhunt with Sony amplifier
- Pioneer speakers
- Alarm with central locking
Too many to list..…..
Service has been done, brand new brakes pads, brand new tyres, brand new clutch.
ALL JDM PARTS ARE BRAND NEW!!! COMES WITH MANUALS.
Asking $17,999 (the parts and labor alone cost more than that)
No time wasters, genuine inquiries only.
Please contact via 0425 747 859 ONLY! i don't come on SAU that much.
https://www.sau.com.au/forums/topic/292394-jdm-type-x-180-show-car/
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
