as per topic guys so far i have hsd coilovers (F8 R7) , strut braces, swaybars and few bushes done
i just wanted to see what setup is best for street driven skyline and also be able to take corners quick
i wanted to see what other people are running?
what else can be done for even better handling?
atm its set to hard front and 2 clicks softer on rear
https://www.sau.com.au/forums/topic/292398-r33-damper-adjustment/
i found trying to get the shock working propery on the spring on a harder setting gave me much better traction than on full soft.
damper adjustment is for getting the shock working properly with the spring/other shocks, not as a street/track knob.
If you are having traction issues, what rear suspension mods have you done, what ride height, alignment, tyres, power?
