Rocker Cover Gasket Replacement
WhitePrincess
  • 3 months later...
Hey, I got my gaskets today but was under the impression they would come with the 'half moons' aswell. Was I supposed to separately order them? You didn't provide a part number so I just assumed it came with the new ones. I have some decent gasket sealer, would you recommend using this on the existing half moon things?
Thanks.
Edited by -Jimmy-
Thanks.
searching on an old thread about this, part # for those cam seals is 11051-58S00
see: http://www.skylinesaustralia.com/forums/Ch...l&hl=rocker (images are all broken)
run a thin line of silicone gasket maker (blue/grey or black stuff, same as you would use for the sump) under the half moons before you install them.
the rest of the cam cover gaskets do not require sealant.
they do require rubber bushes on each screw/bolt in good condition (replace them! or just use 3mm slices of fuel hose like we did in the race car).
most important...do not over-tighten the cam cover bolts...they are meant to be 15-20nm only!!!
  • Like 1
  • 1 month later...
Hey guys,
I also want to replace the rocket cover seals,
as well and paint the covers at the same time :laugh:
Was ready further bak in the thread that the seals are the same for rb20, rb25, an rb26 if this is true dose this mean i can put rb26 rocket covers and rb26 cam covers on at the same time if i can get a hold of sum..??
Cheerz..
  • 8 months later...
Our drift pig is leaking like a b!tch out of the rocker covers and would love to replace them.
Just one question - What the fcuk is this half moon seal you are talking about?!!? Can you point it out to me! Would be greatly appreciated!
I just checked again and he said "Sorry no pics included" of the half moons. Is it actually on the back of the head (accessible easily/easy to change?). If so, once i order the parts i'm sure i can figure out which they are lol.
Well i never seen this thread when i did mine and not wanting to splurge on new gaskets when I did it I used a thin line of sealant (grey stuff from memory) all way around, prolly no need hey, im not even sure they old ones were no good i just did it thinking better safe than sorry :ermm: and now you also have me worried I have overtightened them as well, why is it so important not to overtighten.
Im a pretty bodgey backyard mech at times,
( Although I just invested 25$ in a torque wrench thats about as technological as my toolbox gets), but i dont usually over tighten things just tighten till it stops turning freely then give it a nip. WHile im at it should ex manifold and turbo bolts be torqued or just tighten ?
Cause I just gave them an extra hard nip ... :D
Edited by Arthur T3
well....generally....every bolt with a given strength has a proper torque that it should be tightened to. overtightening is very dangerous because it will stretch the bolt/stud further that it is designed for, causing it to weaken or break. This is very important....overtorqued bolts/studs break all the time, in particular wheel studs. The engineers who decide the right torque have done a heap of testing before deciding on the safe maxiumium torque.
Through the magic of mspaint....
A is elastic phase. while you are here the bolt will basically be fine, forever, over and over. it bounces back.
B is the yeild point. past here you damage that bolt forever
C is the plastic phase....it is changing shape (stretching) forever but has not broken
D you have stuffed it....it just snapped.
The target torque for a faster is normally about 75% of it's yield point (keeps 25% safety margin). An M6 bolt like the cam cover bolts is only 20nm. ie quite light when done by hand.
But.....these are rubber seals and not metal on metal like most bolts. Here they are trying to make sure you don't squash the rubber too far and deform it. so the correct torque is even lighter still. You will see the rubber washers bulge a little, but not be squashed, at the right torque
  • 4 months later...
Great tutorial.
Did this today, took me 2.5hrs working pretty slow. But no leaks so WOOHOO!!
Just a little note though limber up for sure. I think i almost tore a hammy!
  • 1 month later...
  • 1 month later...
Just wana say thank you for this thread, my liner was diagnosed with a leak from rocker cover when its 100,000k service was done in march 08!!! I saw this yesterday and went and bought the kit from bursons and spent the arvo doing and and painting parts at the same time (also replaced intake pipe while it was accessible)
Looking forward to a clean garage floor!!
    • Its also very clearly made to take business away from https://theskylineshed.com/ which is legitimate and even has a physical address.
    • The 'About Us' got me ..  I added something to the cart and clicked 'check out' and none of the payment options in the footer (ie those with buyer protection) were available. Stay the hell away from this one.
    • No. Not true for any non-GTR R32. I think even the GTS4 has the GTSt knuckles with eye type lower shock mounts (as opposed to GTR fork lower shock mounts). The only R chassis in which something like the quote claim is true is the R34, on which the turbos have the fork type and the NAs have the eye type. **Edit: Actually I reserve the right to be wrong about the above statement. It might also be true on R33s. My memory on those shitboxen has faded too much.
    • It's a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind of information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game or stupid enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
