Melbourne Tuners Battle 2009
INFLYTmelb
 Share
Winton fun day that day, 30$
dont mean to be rude or anything mate but this thread is about melbourne tuners battle, not winton fun day so please keep any other event out of micks thread if possible :P
anyways,
gonna be a great day and cant wait my engine setup should be done in 2-3 weeks, then just get the rest of the car ready for the show :D
few tuff cars coming, hopefully alot of you guys from here can come and show off your skylines.
A bit of info about the event wouldn't go astray :D
Is it just an outdoor car show, with a dyno?
If so why is it being called Tuners Battle, unless the dyno is the main feature; but according to your first post the dyno is an added feature/bonus and isn't 100% confirmed.
The flier does nothing to make me want to check it out, let alone enter, as there is no info about what the event is about.
How long has this event been running, in this format, is this the first year?
yea its simply a show n shine and a dyno at a reception centre :happy:
i heard that the owner son is into cars and holds events like this....its will mostly be VL and XR6 turbos...
well then, lets show em how the skyline boiz do it ey :blink:
{TUBZ} its funny you've heard that the owners son, runs these events, as its us, World Advertising, a seperate private entity, who manage and run this event.
Please, show everyone who the skyline boys do it, and FYI, the event is purposly held in an area where public transport is not available, so we dont get the Muztek 16yr olds, you refer to. FYI, we do get mostly, older crowds with families, etc, to this show n shine event.
any other questions, call me, my phone number is on the flyer, instead of creating theories based on mere judgement, i'll be happy to answer any questions, or take on suggestions.
regards,
Mick.
  • 1 month later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
