hey guys, just installed a blitz bov into my 32 today. got it second hand off someone and it came with the pipe.
i had a plate to block off the standard bov made up yesterday, its bolted on and sealed to stop any leaking where the stock bov was. i have taken a vacuum line to the top of the blitz bov which is mounted down near the air filter. and the pipe that was plumbing back the stock bov is sealed tight.
issue im having is that now when i drive the car, its hesitating and farting around up at 4500rpm. its doin the same as when the boost is too high. feels like its not gettin enough fuel or the spark plugs are f**ked or something.
i've triple checked everything i've done and everything is tight so i dunno whats goin on.
any help would be awesome....
https://www.sau.com.au/forums/topic/292434-r32-playing-up-after-bov-installed/
Coil packs mate, get one of your mate's coil packs and chuck em on your car, 99% of the time its the coil packs.
sweet as mate thanks, i will swap the coil packs n put new spark plugs in on my next day off, i'll also fill it up with some new fuel coz the car has been sitting for about a week so maybe fuel is going stale. i'll run some injector cleaner thru it as well and see how that goes.
bov is also really quite for some reason but might just been the spring being too hard for boost. i adjusted it so it was as loose as it would go so might organise a new spring for it. im only running like 8 pound thru it...
Put the factory BOV back on first.
If the problem is still there, then continue investigations. Until you do this however, anything else (like the below), is pointless.
He has only changed the BOV, and the issues start immediately after it.
And then that suddenly makes it coilpacks with a 99% chance?
The spring tension is there to adjust how fast your BOV closes after it vents. The vaccum hose on the top is what keeps it closed under boost. This could be your problem right off the bat. If you have it at it's weakest setting like you say you do then your BOV won't be closing fast enough or maybe not at all (until you stab the throttle which will cause it to snap shut. Adjust your spring tension to be firmer and see how you go. The Blitz valve is pretty loud if you have the trumpet on it but otherwise I've been told it's average. Mine had the trumpet but seriously consider either stock, GTR or after market recirc valve as the rich running, idle issues and wank factor of teh pshht noise of a poorly setup atmo BOV are not as ideal as teh recirc valve that does the same thing (legally) as any other BOV without the loud noise.
But yeah I seriously doubt it's your coilpacks or anything evn remotely to do with your ignition system. This has air leak written all over it.
BOV is most likely shagged.
which one is it? if it is the old style one (one mounted to pipe in pic) bin it as they are all 15-20 years old. I have NEVER found a good one of the early types.
there are 3 springs for the blitz bov, and you're prob. only hearing the sound from your pod filter if its whooshing... open the blow off valve and check wat colour spring it is...the old school blitz bov are the best if you're looking for something very loud ive got one on my car...when pulled apart u can cut off a couple of coils to reduce tension, also clean it and oil it up with some sewing machine oil and its sweet...to check what spring you have go on blitz website and identify colour with one you have and it states what psi to spring rate you have... good luck...any issues get a ss drive blitz bov and pm me, can show u how to modify it to be as loud as the older style blitz ones...
Just run your stock one vented to atmosphere if you want some more noise, the stock ones sound alright plumbed back with a pod even. The one you just installed probably is possibly faulty or its not getting a proper vac signal, I'd run the vac line from the manifold not the air filter as the pressure isn't going to be the same there. The closer to the throttle body the vac line is the better. Why not just extend the vac line the stock bov uses ? Will rule that out as an issue
Edited by Rolls
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
