I just picked this up as advertised an an "r33 recirc valve" however Im thinking that this isnt what it is. I sort of suspected this when I bought it but it was just a fraction of the $50 that most people charge for one on this site. Can anyone tell me what it is? or if it is possible that I could use this on my 33 gtst?
Edited by Crackfox
https://www.sau.com.au/forums/topic/292461-what-is-this-part/
I am pretty sure that it is a GTR type twin recirc valve and I am currently fitting one of the recirc valves to my skyline, I'm currently installing it and will see how it goes, looking like the only modification needed will be from the different pipe sizes which is an easy fix. Will see how it runs soon
OK so its a GTR bov? not bad for $10 then I guess:p The guy selling it didnt know much about it, he drove an audi and when I asked which model skyline he used to own he said he had never even owned a nissan so I dunno how he obtained it.
I have taken one of the recirc valves off and installed it on my skyline. Is the only difference between the gtst and gtr recirc valves the pipe sizes on the larger end? can anyone confirm this or are is there other changes as well?
Seems to run fine with the new recirc valve, now it makes a funny "pchieww" type noise instead of pshhhhttt at gear changes, the cars responsiveness also seems ever so slightly decreased though it is a very subtle difference which is expected I guess. The cars small backfiring issue and occasionally lumpy idle also appear to be solved.
just get a mirage 1.5 radiator hose and cut it and it will fit to gtr bov and gtst stock plumb back piping :cool:
i posted the part number sum where but cant seem to remember what part number it was
I just connected it by putting a piece of the smaller gtst bov type piping inside the larger gtr rubber piping, and then put a radiator clip thingie on it and joined it as normal. I don't think its leaking but I may test it further just to be sure.
*cough* dodgey *cough*
Why is it dodgey? Its a more secure fit than the stock plumback connection, if any connection does fail on my installation work it wont be this part. Anyway I would rate my work as alot better than the very messy previous atmospheric blow off valve installation.
Well the GTST ones aren't too flash for high boost and they do have a little hole in them that leaks off air a bit. People weld this up and then supposibly its fine for high boost. No idea why it is there from factory, maybe some one else can explain that. Perhaps a safety for a boost spike so it bleeds it off? I believe the GTR ones don't have this hole hence why they hold higher boost fine.
Edited by PM-R33
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
