hey, im interested in doing the 5 stud conversion on my r33, however i cant find any complete guides on doing so... or more to the point, a complete list of parts needed to do it.
ive searched and found a few threads on it already, but so far, most of them have been saying different things about needing to replace parts of the braking system and what not.
also would anyone have all the parts to do the conversion sitting around for sale? :D
cheers for any points in the right direction XD
https://www.sau.com.au/forums/topic/292464-r33-5-stud-conversion/
Get the turbo's 4 piston calipers with the bolts!, and rear 2 piston setup with 298mm rear disc and drum for the handbrake. The whole rear hub setup will have the handbrake stuff on it.
Then you need to see if the center spline of your driveshafts that runs through the rear wheel bearing is smaller than the turbo version...
i did this mod on my 4stud r32
got r33 turbo rear hubs and r32 front hubs, came with brake calipers, rotors and handbrake cables still attached
i found my driveshaft spline was the same and fit the turbo hubs
u need a big socket to undo the driveshaft nut from the hub, think its a 36mm socket
i upgraded my brakes at the same time and found that once i went for the first drive i had no braking pressure, adjusted the brake pedal where it connects to the brake master and i got brake pressure,
if u do upgrade the brakes i ur brake lines may have banjo fittings where they bolt to the caliper so you'll have to work something out
  • 3 months later...
ITEMS FOR SALE:
TO SUIT SOMEONE WILLNG TO DO A 5 STUD CONVERSION.
1. FRONT AND REAR HUBS OUT OF A GTST R33.
2. R34 GTT WHEELS(5STUD) FOR SALE WITH TYRES.
ITEM LOCATION: MELBOURNE VICTORIA3178
DELIVERY: BUYER TO ORGANISE
PRICE FOR THE HUBS $350
WHEELS: $550
ANY ONE INTERESTED GIVE ME A CALL 0403673876
  • 4 weeks later...
thats random, i sold sajid_arif those wheel hubs like a month ago, apparently they got damaged in the post, seems like they must be alright now, i bet they were always alright he just decided he didnt want them anymore so tried to make an excuse for refund. LOL
Edited by azzafreddy
  • 5 months later...
Didnet want to start another thread, Could a Brake upgrade be done on a R33 GTS4 without a 5 stud conversion, Say rotors and calipers of an AWD stagea?
Been trying to look for the Brake sizes aswell with no luck, info appreciated
/Thread Hijack
I've got a set of front Bendix Ultimates to suit R33 4 Pots :banana: preferably wanting to get rid of them this week before Thursday! $50 pickup or throw in a bit for postage. Barely used, bit coarse for my liking so I changed pads. PM if you want them.
/End Thread Hijackk
  N-DAWG said:
/Thread Hijack
I've got a set of front Bendix Ultimates to suit R33 4 Pots :D preferably wanting to get rid of them this week before Thursday! $50 pickup or throw in a bit for postage. Barely used, bit coarse for my liking so I changed pads. PM if you want them.
/End Thread Hijackk
You find they were you rotors out quicker then other pads? Also will they fit N/A 33 brakes. what the part number of them so i can check them out. im keen on them
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
