I only ran it for 20 or so seconds...maybe (hopefully this will be the issue?) How does the fuel get dumped in the cylinder when you remove the injectors? When I pulled out the stock rail and injectors no fuel came out until I popped out the stock injectors - then the rail was quite dry when I put in the S15 ones?
Ahh i always leave the rail in place, when changing injectors, save alot of time (we do round 3 sets a week).
OK....well I got off work early today, so had a chance to play with the PFC....
Adjusted the injectors' % and lag times to the recommended values (tried everything in this thread) without success. Also dropped all of them right back to 25% - the AFR increased slightly to around 13 - 14, but it was still running rich, idling really rough, missing (?) when revved, and blowing smoke (fuel) out the exhaust....
I'll take the injectors and fuel rail out on Saturday and take it to a fuel injection shop....
When I take it to the shop what should I ask for, or ask them to do?
Can anyone recommend any fuel injections specialists around Perth, WA?
Thanks,
Peter
I don't suppose you accidently changed your AFM setting in the Power FC ?
I did that once when poking around and rang my tuner staight away thinking i'd ruined my $500 tune.
Mine was blowing black smoke and so rough it was ridiculous.
That was the 1st thing he said to check.....i accidently flipped it to something other than standard R33, flicked it back and hew presto! Just an idea.....good luck
Thanks for the suggestion Birnie.
No AFM is still the same, I have a Z32 and this is selected within the AFM menu.
Thanks for the suggestion anyways!
Pete
ill still bet money its a nicked o-ring on the injectors.....
I have said it before in this thread THE CAR WILL RUN FINE WITH THE INJECTORS SET TO 100% IN THE PFC AS THEY ARE ONLY SLIGHTLY BIGGER THAN STD 440 up from 370cc..... You have another issue, nicked or incorrect oring.... i see this about 3 times a week @ my shop from guys incorrectly fitting them themselves.
Edited by URAS
Yeah, I think this is the issue....pulled the fuel rail with injectors out today and there was fuel leaking around the pintle caps. Left the fuel rail sitting in the sink for a while, and a few of the injectors continued to leak fuel from around the pintle caps...must be the o-rings...
I don't understand though...I bought the right o-rings, fitted them, and as the injector shop recommended, sprayed a bit of WD40 on them and slid them into the rail...they weren't sticking or anything... I did the final tighten with the end caps and screws....oh well...off to the injector shop to get them to fit, clean and flow...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
