R33 GTST S1
It's a clear crisp CLICK. Not a thud, or bang, or grinding.
It sounds like it's coming from the rear driver's side wheel. But then i've only heard it when driving, so it's hard to say.
It will happen (sometimes) when coasting in neutral at low speeds, and then selecting 2nd.
Or when blipping the throttle at very low speeds. So basically when it's throttle off/on/off suddenly, but only on light throttle, and only sometimes.
Like a small shock to the drivetrain. I was thinking diff or uni, but would they make a sharp click?
The noise has been there for a long long time. I've changed suspension and clutch during this period. So theyre ruled out.
Maybe someone has had this CLICK before and can narrow it down to a couple of high probabilty areas to check.
Cheers
https://www.sau.com.au/forums/topic/292538-noise-coming-from-rear-wheel-area/
At those low speeds (say in 2nd), does the click become prominent as you switch from accel > decel > accel > decel??
The diff can make that noise. May need to change or simply top up diff oil.
Nissan mailed me 'under recall' to bring in my former R31 Silhouette with LSD to change the diff oil & the clicking stopped.
hmm good question. i'm pretty sure it's never happened more than once at a time. maybe i havent tried. but no, it doesnt become more prominent. although decel>accel at low speeds will cause it. just not always.
if it's just diff oil, that would be a good outcome :banana:
I have the same issue, and have had since I got the car.
Last service I asked for a diff oil change... car still makes the noise though.
I'll be changing it myself sometime soon(ish) when I get a chance, just to be sure that it's been changed then.
the click i get isnt constant. its a one off every so often. thats why i'm thinking diff oil probably isnt the issue.
i will most likely change it anyway, for general well being.
if i find the issue, i'll definitely post it up here.
the diff oil could still be the issue as the angle of the ground you are on at the time may be affecting what the oil is covering. it isn't hard to change the diff oil. i'm sure even someone with girly hair like you could manage it, LOL
Check rear suspension bushes, exhaust mounts + bolt tightness in general.. worst case scenario - excessive backlash (space between gear teeth before they make contact) between the crown wheel and the pinion inside your diff, can be adjusted with careful precision :laugh: if you can safely raise the rear of the vehicle and drive it, a mate can use a mechanics stethoscope (or a metal bar/screwdriver :D) and place it on the diff housing (don't inhale exhaust fumes or get caught in spinning wheels!) to listen for excessive grinding, knocking etc (very thorough way to check how your diff is going)
check the wear in the outer joint of the half shaft, so pull the half shaft out (CV) and knock the outer off, clean it, regrease it and clamp the boot back on, could be wear there.. sounds to me like a worn outer.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
