Finished off a couple other things. Made up some heat shielding for the new turbo as you cant use the stock heat shield. I used some ceramic cored aluminium sheet, its about 3mm thick and apparently good for around 800-900c. it was really easy to work with and form. it seems to be doing the trick, the cables and pipe work in the corner with the abs aren't getting as much heat soak anymore.
today i also got around to installing a new set of coilovers which i desperately needed. on my recent trip up to my brothers, 400km away, with 4 adults, luggage and not the best roads, i managed to blow out the rear left shock and the right hand side was starting to leak. i wasn't too fussed as i had some new ones to go in, and considering it was still the 10 year old stock suspension, i wasn't surprised.
i set the new coilovers to 50mm lower than the stock ones, which only gave me about a 25-30mm drop all round (i was expecting this), fronts are the same height left to right, but in the rear, the side with the fuel tank sits slightly lower than the other, i'll fix this up tomorrow. Give the springs a few days to settle then drop it down some more and off to get the alignment checked. i'll be getting some adjustable camber arms or bushes this week to allow me to drop it and still get a good setup.
  • 1 year later...
  • Replies 47
Posted Images
Looking good Josh! Will be interested to know what your dyno graph looks like when you've finished tuning. Roughly what horsepower is your GT35 capable of?
yeah i'm keeping my eyes out for a dyno day or any opportunity to get it on one to see how its going. i first tuned it to 14psi as i had a couple other things to sort out, just recently i've tuned it up to 20psi so i'm keen to see what power its making. the GT35 is rated 400-600 hp. i want to see it around 400hp to start with, then once i forge the engine, go for more.
Which exhaust housing do you have (using .63 on mine)?
i'm using the .82 internal gate housing.
nice. but with running that amount of boost and 400hp, your'e really pushing the stock internals to the limit. i would also recommend a 1.8mm head gasket. ;)
Had I my time over again I'd have stuck with the stock pistons and gone for 500hp and waited until something broke, *then* rebuilt lol...
Josh what is the boost build like on a GT35? My GCG highflow is pretty much as responsive as stock but makes more power everywhere. I would like something that will make real power though...
i've seen plenty of examples and personally know of a few engines running that sort of power on stock internals and they continue to do so safely. i've been running this setup for over a year now, and 20psi for a little over 6months and the engine still has good compression and runs nice and smooth. i know where your coming from when mentioning the thicker head gasket, but i'm not too bothered about it, 20psi is still be ok on the stock one and i'm not too keen on opening the engine before i'm ready to do a forged rebuild.
Dave the GT35 is a completely different power delivery, i imagine yours is a smooth increase in power, the GT35 hits hard, like doubling your power in a second lol. i get about 5-7psi from 2500-3000rpm, which i would compare to the same feeling as a stock turbo on 10psi. i get a slight increase in boost, maybe 5psi then as the revs increase until it hits hard at about 4000rpm. i have lifted my rev limit to make use of the later onset of power. it is a laggy turbo but that how i like it, not once has it annoyed me to the point where i wanted to replace it. it is a bit slow off the line but once power is on, with the auto, it will hold through the gears.
it depends on what type of power curve you like Dave, the GT30 is popular, a little less laggy and will still get you too 400hp, i probably would have gotten one if the GT35 and associated parts didn't come up so cheap (i got it off a friend). hi flows are good as they retain stock turbo response and give more up top, which is good for people who dont want to sacrifice a bit of low down for more up top.
i also wouldn't mind trying the .63 rear housing to see how that performs compared to the .82, but it all costs money and i cant justify shelling out $1000+ to try a different house that might not make that big of a difference anyway.
Edited by QWK32
Here is a quote from a workshop owner in Wellington:
A basic example of somthing we have tested at work.
RB30DET, usual standard mods, GT3582R. with a .63 on 14psi it made 300kw. with a .82 it made 330kw, though boost came on 500rpm later.
On 18psi the .63 made 350kw, where as the .82 made 375kw (could have made more but the power was more then enough for a street car)
The owner with the .82 exhuast housing, is looking to down size as the car isn't as responcive as he would like 4000rpm full boost.
That's on an RB30 but I guess the principle would be the same - changing to a .63 housing will bring boost on about 500rpm earlier and cost you 35kw at the top end.
I guess if you are used to how your car drives now there is no need to change but if you did want to change you could probably find some one with a .63 housing who wanted more top end and do a swap!
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
