Gday guys, got a heap of rb26 bits that ive been collecting, but not going ahead with this build now so its all up for sale
happy to post at buyers expense.. will supply pictures tonight or on request
parts to suit rb26 and are brand new unless stated otherwise
1- 6 boost manifold t3 flanged has turbosmart progate fitting welded on $900
2- turbosmart progate 48mm $600
3- arp head studs $380
4- denso/sard injectors 660cc (used, will supply part number soon) $500
5- power enterprise triple plate clutch (used, good condition) comes complete, flywheel disks and thrust bearing. $500
6- hks cam gears $350 purple and blue/green colour ones
7- acl multi layer head gasket $ 220
8- rb26dett throttle assemblies x3 $100
9- gtr standard injectors used $200
10- standard rb26 cams (used excellent condition) $150
11- apexi air cleaner kit, 2x aircleaners,alloy fittings $200
12- tomei/jun head , rb26 head built up in japan.. has tomei phospor guides,tomei springs and retainers, light port and polish, jun 272 10.8mm cams being shimmed now, will be ready by end of week. $2800
13- rb26dett block, decked acid dipped, bored, torque plate honed, r32 crank with extended nose, cradle and block line bored for straightness.. acl/ross 87mm forged pistons, eagle rods, acl bearings clearances checked ready to be assembled. $3900
14- n1 pump used for 1200kms $380
15- n1 water pump brand new $290.00
heaps more, this is all i could remember right now:) will update tonight.
pm or call 0403600810
cheers
https://www.sau.com.au/forums/topic/292553-rb26-performance-parts/
Push or pull? If push, will you ship to Norway?
Best regards
Petter
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
