Gday guys, got a heap of rb26 bits that ive been collecting, but not going ahead with this build now so its all up for sale
happy to post at buyers expense.. will supply pictures tonight or on request
parts to suit rb26 and are brand new unless stated otherwise
1- 6 boost manifold t3 flanged has turbosmart progate fitting welded on $900
2- turbosmart progate 48mm $600
3- arp head studs $380
4- denso/sard injectors 660cc (used, will supply part number soon) $500
5- power enterprise triple plate clutch (used, good condition) comes complete, flywheel disks and thrust bearing. $500
6- hks cam gears $350 purple and blue/green colour ones
7- acl multi layer head gasket $ 220
8- rb26dett throttle assemblies x3 $100
9- gtr standard injectors used $200
10- standard rb26 cams (used excellent condition) $150
11- apexi air cleaner kit, 2x aircleaners,alloy fittings $200
12- tomei/jun head , rb26 head built up in japan.. has tomei phospor guides,tomei springs and retainers, light port and polish, jun 272 10.8mm cams being shimmed now, will be ready by end of week. $2800
13- rb26dett block, decked acid dipped, bored, torque plate honed, r32 crank with extended nose, cradle and block line bored for straightness.. acl/ross 87mm forged pistons, eagle rods, acl bearings clearances checked ready to be assembled. $3900
14- n1 pump used for 1200kms $380
15- n1 water pump brand new $290.00
heaps more, this is all i could remember right now:) will update tonight.
pm or call 0403600810
cheers
https://www.sau.com.au/forums/topic/292553-rb26-performance-parts/
Push or pull? If push, will you ship to Norway?
Best regards
Petter
