How many have you got?
Is that $200 for the lot?
Exactly which Dunlops are they?
When were they last used?
Where have they been stored since then?
Can you post up a pic showing the tread condition?
I know it seems like a lot of questions but I looked at buying some not long back and when I saw them they were crap even though advertised as good usable tyres.
Am very interested as I need some before the 8th of November when my next Club Day is scheduled.
anyone ??????
Anyone???
Your kidding right?? :banana:
I have been waiting and waiting for you to come back with the info you said you were getting.
Been to Launnie twice since then, once for a club day.
Your welcome to em Funz.
I'll just buy brand new ones for next year, did a clutch in the GTR on Sunday anyway.
Edited by SSHatch
Anyone???
Your kidding right?? :)
what more info do u want there compound m2r dunlop semi's
they sell for nearly 2g new i want 200 bucks for them they heaps off tread left u there 17's
they come off a front running targa A class car only stopped using them cause he went to 18's done one race meeting i think
there isn't that much difference in a 235 to 245
M2 are a medium compound.
ideal for club days and hill climbs. they would offer exceptional grip in the wet too. not suited for long distance like targa and alike.
i have some that i will be using this weekend and i have used them before.
ive always brought second hand semies and compared to $600 each $50 is cheap. cheaper than you would ever get a set of used road tyres for.
if your to tight to buy $50 tyres for your race car than youll never buy new ones. we flat spotted a brand new one once and it stuffed the tyre $600 good bye.
Who said anything about being to tight to buy second hand tyres?
I ran second hand ones this year while chasing starting tyre pressures and the like. I also knew my alignment wasn't right but until I get some adjustable arms couldnt do anything about it so didnt want to trash new tyres.
I was more than happy to travel down and buy these tyres once I knew what the tyres were. There are 3 different patterns available in the tarmac rally tyres made by Dunlop, I was unable to find any on the Dunlop site in the Semi range in that size.
i was thinking the same thing damo
there direzza o2g's m2 there in lonnie i'l be hobart on friday if anyone wants them drop off
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
