So what happened to you getting it done under the warranty you were so sure you were going to get? :bunny:
Told you it wouldn't be fixed for free. :cool:
For $1200 id be talking to hypergear about a brand new turbo
Try the ART28G4 including internal gate kit oil line and dump pipe its costing me $1330 delivered will flow over 300rwkw
Why would he put a bush bearing turbo in place of the ball bearing he has now?
Makes little sense to me, especially when the GCG turbo is ready to go. Just new wheels and cartridge.
The GCG item is superior in every way, and hence they are $1700 or whatever new as opposed to cheaper hi-flows which are $1200
  • Replies 42
So what happened to you getting it done under the warranty you were so sure you were going to get? ;)
I can't be f**ked arguing with them, I could get it sent back, get bill to do a full inspection but then I would have to take them to court, I was hoping it was an installation error or something clear cut that I could get the workshop to pay for but if it was a balancing issue then because it seized (would have cooked everything when that happened) it probably has all the signs of excessive EGTs and Id just have my thumb up my bum for months.
You love rubbing salt in peoples wounds don't you nismoid :bunny: sure you are probably right most the time but you come across as a cynical cranky old man some times lol.
I guess I could ask for all the damaged parts to be sent back with the new turbo, that would be a fair request wouldn't it? then I could get a third party specialist to examine the damage. In fact I think I will do that, not like they can re use the wheels, bent shaft and shagged bearings.
Well since GCG build your turbo its probably good idea to work some thing out with them.
If you can't work things out, and assume it is a Garrett BB CHRA that is in it and your turbine wheel is not broken we should be able to overhaul it for you in its original Ball bearing form for lot less then $1200.
Also for our sleeve bearing units. Well it is cheaper to build, and I believe this is still the most reliable setup for aged engines. I still get full boost at 3500RPM out of our 520HP Turbo. We've lighted the shaft and modified the bearings for minimum friction, its not really the same as the older Garrett's sleeve setups.
Yeah I've already given them the go ahead but I'm going to ask for the bits back.
You could honestly do new bearings, front + rear wheel, shaft and balancing for _a lot_ less than $1200? How much is a lot, and do you use the same parts? This is more out of curiosity as they have probably already started work on it.
Both wheels have hit the housing but it was only for maybe 30 seconds under vac so the damage is minimal, however with something that spins at 150,000rpm I really doubt that you would risk re using it even after putting it on a balancing machine.
You love rubbing salt in peoples wounds don't you nismoid :cool: sure you are probably right most the time but you come across as a cynical cranky old man some times lol.
Sometimes people just have to find out for themselves :bunny:
If there are markings as GCG say - you will NEVER be able to prove otherwise mate. Just because you are running 12:1 AFR on that day doesn't mean there was an issue with the motor/car before you brought it or any other situation i could easily think of ;)
If there are blue scores on the bearings etc, it could also be oil related as other people have said - it is very easy to have a turbo inlet block up.
If you can't work things out with them, and assume it is a Garrett BB CHRA that is in it and your turbine wheel is not broken we should be able to overhaul it for you in its original Ball bearing form for lot less then $1200.
Cartridge is what, $1000? Plus new wheels, balancing and machining whatever damage the wheels did (which sounds like there is some)
For $1200, it is a good price. You won't get a ball bearing turbo rebuild for any less than that IMO.
If its getting 1.6L/minute of good uncontaminated oil at idle then surely oil can be ruled out?
And yes I agree, I think this is definitely my cheapest option and from someone else's perspective a very good price, I am happy they aren't charging me labour as well.
At the end of they day I got the car for a steal with $20k in receipts so although I'm coughing up for it now I will still come out further ahead than if I did all this work myself.
Now as for when the turbo goes back on the car, to make sure I do not have a repeat episode what should I check?
The cat and mufflers are not blocked, the oil and water supply appears clean and to flow sufficiently, the car will be getting a completely new tune from a different tuner. I will also request that they laser gun the dump pipe/housing to see what sort of temps it is getting. What else should I be checking?
Edited by Rolls
To overhaul the turbo with original Garrett Ball bearing bit is $700. And a comp wheel is $180. slap every thing together and you are back on the road.
The turbine shaft is the most expansive part, depends on the part No. They cost aorund $300.
The Oil out put volume is fine for BB CHRAs. They don't needs much oil to run, But the oil that goes into it needs to be very clean.
The turbine shaft is the most expansive part, if that is not good then we need to check up the part No. and get you a price on that. They'll be aorund $300 mark.
Quite sure this is what caused the issue, it was running off centre due to it being out of balance, or the balancing weight drooping. So I imagine this is gone.
So yeah thats $700 + $180 + $300 + rear wheel + assembly and freight >= $1200
Thanks for the offer though. :cool:
edit: I've been advised that a blocked oil drain could cause the oil burning that I experienced but put down to poor sealing on the forged pistons, how would I check that the oil drain is not blocked and is working correctly?
I plan to remove the line and check that it is not blocked, but how would I check that the actual drain into the block is not partially blocked?
Edited by Rolls
Depends on how bad the turbine shaft is. In most of the time its the ring grove that wears. That could be sleeved and re cut pretty cheaply. and even it is bent we have machines to make it straight. But if the fins are broken or gone then that can not be re-used.
so let me get this right? the turbo was unbalance? and you are paying for it to be replaced or fixed?
No they said the cause was excessive EGTs, the turbo guy here in Adelaide said thats a load of shit and it is far more likely it was not balanced correctly.
There is absolutely no way to prove that they are lying to me so I have to suck it up and pay. What would you do Kaido_RR ? I could ask for the turbo to be sent back, get an independent investigation to the failure, it will probably be inconclusive but leaning one way, I then have to take them to court and chances are I dont win, I burn my bridges and they will no longer deal with me. I am then left with nothing. Also the turbo is out of warranty, technically however if it is deemed an unreasonable failure I can still take them to court and get the repair for free, but then I have to prove that the turbo failure was 'unreasonable' even though it was out of its 12 month warranty. I can't prove the turbo wasn't used everyday for that period and that my 2500km claim is true.
At least this way I get a new turbo with 12 month warranty for fairly cheap, I am still going to ask for the broken bits back though so I can get some sort of opinion on the mode of failure that is 100% un biased.
Edited by Rolls
fair enough, its just that i would not be buying the same turbo again.
having a turbo unbalance is a pretty big deal, don't understand how a brand new turbo can have this issue if the company has the correct quality control.
If you read the rest of the thread you would see that for the price I am paying nothing will come close, anything even similar will be an extra $500-700 in cost for no gain.
If it took 2500kms for the turbo to fail it would have to have been an impossibly small imbalance, anything else would cause the turbo to shit itself almost immediately, it most likely would not have shown up on their machine, otherwise as you said their quality control would not have let it be sold.
I personally believe that I just got unlucky, you don't hear theres stories very often.
If there are blue scores as GCG said - they how do you deduce balancing?
Where did you even pull that from? The person who said it was balancing has not even pulled the turbo apart, so its nothing more than speculation.
The turbo did seize at one put so I imagine that would have caused severe overheating as I reved it to about 4 under-load as I wasn't sure what had happened. Could have been the cause of the blue scores. The exhaust wheel showed no signs of overheating though.
I personally think they are just taking you for a ride, it was probably their fault but they know you really cant do much about it so have decided to charge you to rebuild it.
Its a lot of hassle to get an independant person to look at it then take it to a small claims court, but then you would probably at least get your money back.
That said, id say you have probably done $1200 bucks worth of damage to GCG's reputation as a result, so dont feel too bad.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
