A few years ago myself and my old man built this car. The original plan was to race it on the circuit, but dad was always too busy to put the time into putting in competitions. It's been complete for close to 2 years and has only seen the circuit twice, the first time with major clutch issues, the second time in the wet. It's seen the drag strip twice also, the first time also with the fail clutch, the second time after a replacement.
As you can see in the pictures, the inside of the car is completely stripped, custom dash with far too many gauges, full rollcage, 5 point harnesses and bucket seats. The car weighs roughly 1300kg and is sitting on 425hp at the wheels on a soft tune of 16psi. The engine completely rebuilt rb30 with forged internals, running a GT3540 turbo. The radiator is from Glen Seton's V8 supercar from...2004 i think. The huge brake calipers are also off a V8 supercar, but i forget exactly which one.
As of now its best 1/4 mile time is 12.7, this with some traction problems at the line. As the car is now, we should get it close to breaking the 11 second mark. Today we are installing a Greddy profec bspec2 electronic boost gauge, then we are going to set a lowboost of 17 psi, and a high boost of 20 psi. With this added power and a set of semi slick tyres we are hoping to get into the high to mid 11s at the drag strip tommorow.
https://www.sau.com.au/forums/topic/292672-r31-trackdrag-car/
such a shame to waste such a beautiful car on the drag strip. bring it to the next SAU track day....you will love it and appreciatethe car so much more. FYI the car at 1300kg and 400hp should be good for mid 11s
Yeah, with practice getting shift points right and managing traction, mid 11s for sure. We are putting a short shifter in when it arrives which should help a bit.
We didnt end up going to the drag strip, we came across some issues with the boost controller, and the clutch master cylinder is playing up too. We are getting it tuned properly on a dyno tommorow. I will be videoing it, so i will pop that on youtube tommorow arvo.
Dyno results?
Dyno results?
We've come across more problems. The boost controller is supposedly tuned, but we are losing power for some reason. Low boost is set to 18 psi, and high boost is set to 22 psi. The dyno sheet shows a nice high curve of power up to 4250 rpm, but after that the curve flattens totally. I'll attach an image of the dyno sheet. Hopefully someone has an idea of what could be causing this drop in power.
what valve springs are in engine?
that looks pretty spot on to me... power builds strong as boost rises and then flattens off as it holds boost
im guessing your not used to looking at turbo power graphs?
I've seen enough. And im not the only one who sees problems with what its doing. My old man, the tuners and a few mates ive spoken to think something is wrong. And does 420hp at 22 psi sound about right to you? the car was making 425hp at 16 psi before the boost controller change. The dyno sheet from its soft tune looked completely different, the curve was smoothe all the way to redline, there was no sharp drop in power as the rpm got higher.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
