Hi,
I've got an EP82 Toyota starlet. Like most imported cars, these things run rich straight out of factory. I recently wack a SS mainfold, SR20 turbo in it. Car runs beautiful on boost but off boost is an issue......
It runs way too rich off boost (from 2000rpm to 3500rpm) to a point where it created mis-fire sometime. I've checked everything, thermal switch works, watertemp sensor works, O2 sensor works, engine light don't come up, change sparkies, change igintion leads.......ect still won't fix the problem.
Long shot here on this forums but someone might have an answer,
Thanks
https://www.sau.com.au/forums/topic/292697-map-sensor-car-running-way-too-rich/
Get an aftermarket ECU and tune it properly? Of course its not going to run properly. It would be expecting the tiny turbo to be on boost much sooner so thats probably why its overfueling down low. Could be running lean on boost as well. Seriously get it tuned with a copgy back fuel controller or a full ecu asap before you break it.
Edited by Rolls
Thanks,
What i thought but i also thought that it should be able to sense boost pressure, when boost kick in and such but i guess not :P. SAFC it is.
Thanks,
What i thought but i also thought that it should be able to sense boost pressure, when boost kick in and such but i guess not :P . SAFC it is.
It will but who knows what the max level the stock map sensor can handle? Its probably reaching load points its not meant to and running wrong size injectors etc. I'd be betting the stock computer is just going wtf and not knowing what to do.
I had a Starlet once, and you do not need a remap, the map sensor reads until 1,25 bar. Stock injectors will make 200hp for sure.
Check your vaccum hoses, it is VERY possible tha this is the cause.
Just because it can sense that much doesn't mean it knows what to do with the values. How do we know what the manafactures had in mind when they programmed the computer? If it exceeds load cells and the max pressure it expects to run it could just dump fuel and retard timing all over the board for a preset amount of time. There's no way to know.
Yeah, i've been told about Vacum hoses, has done lots of checking but not on the dyno so can't really tell while its under pressure.
Turbo A and Turbo B can both be at the same boost pressure... The difference is, they're flowing different amounts of air.
This is why the tune is up the shit.
Go and get it tuned. Nothing else to be said.
Guys,
I did a stupid test :) , ran the car with the O2 sensor un-plug and guess what...........it ran faultlessly lol. Does that mean the O2 sensor shat itself?
Quite likely, I would still put it on a dyno, you don't want to pop your motor because its pinging/running lean/rich. Only cost you $50 or so.
Oh yeah i'm still going to run it on a dyno first just to be safe but i think at least i've got to the bottom of it.....phew.
Guys it was making problems OFF BOOST, there was no problem when on boost, nothing to do with tune when off boost. 4EFTE's are very rich from the factory they handle EXTREMELY well at 0.6 boost with OEM setup, Trust me i had one with 315hp and searched a lot.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
