Apparently people were saying that almost all after market cam gears have weak teeth and crack easy. So I guess that would be a con. Also why spend 300 to buy them about 100 to install to get 3/4kw - 400 bux = new coil packs which you'll most likely need sooner rather than later
"apparently"...what people???
Sorry mate, but I've never heard anyone on this forum or in real life say that, early HKS not withstanding. As for the pros and cons, the use of cam gears is part of the whole upgrade. They provide the Tuner with more scope for adjustment of the separation or overlap of the cams for better response or out right power.
There was a pic of absolutely worn out teeth on a pair HKS cam gears from a busted 2J that was doing the rounds on the interweb about 4-5 years ago. That gave rise to the myth (or not a myth - whatever). Something to do with a weaker form of alloy used in the construction of them.
There was also a story about them from the same era about not have enough locating on them, leading to slippage.
How much of this is true i don't know, just sharing the rumours of a few years back.
I've actually seen a motor (RB25 IIRC) that ate all of it's valves on the exhaust side. The "adjustment" was all the way to one side. The shop guy surmised that either the adjustment slipped and ate all the valves, or when it ate the valves for what ever reason, it forced the adjustment all the way to one side. Either way, the 3 bolts holding the adjustment in place slipped and it didn't seem like there was enough clamping force there. I run HKS gears, but I'd prefer something else just for peace of mind.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
