Hi guys, I have been considering an aftermarket mechanical LSD, probably a Kaaz 1.5 -way and was wondering if anyone has experience / an opinion on the durability of these.
My car is an R33 GTST with some basic mods and is my daily driver. I want the diff for the odd track day here and there and for the occasional traffic-light grand prix.
I have read plenty of positive reviews here about the aftermarket LSDs but ultimately I want something that is also going to last. If the Kaaz unit isn't going to give me more than say 20,000km then maybe I would be better off shimming up the standard diff every so often?
Any advice appreciated
is your concern based on anything ? and what exactly are you woried will wear out ?
Just worried about how quickly the friction plates might wear out.
I guess my concern was that while I had read a lot of positive information about these diffs, I couldn't seem to find any info about how long they last.
I just don't really want to spend $1300 or thereabouts on a new diff and then have to replace it after 18months of mainly street driving.
If anyone has any experience with these things on a daily driver and has got a decent amount of kms out of it, be it the Kaaz, Nismo, Tomei, I would be interested to know.
My shimmed/rebuild stock diff is mechanical, it was the first thing done really, and that was about 10,000-15,000 ago now. Still going strong without a hint of issues.
A Kaaz would be the same, as with all other diff's. Nothing will last however if you abuse it every day of its life
It's the length of a piece of string mate. There's no exact km a diff or gearbox will last, there's not even an approximate. Even on the known weak gearboxes I deal with there can be 80,000km difference between two cars when the "factory faults" begin to show.
A diff, even mechanical LSD, can outlast the engine if you drive it with that as your goal...it can last you 10 minutes if that is not your goal. Don't expect to get away with treating mechanical items harshly and being able to use mileage as some sort of wear indicator, because something can go on you at any minute.
The worst mistake people make is not running in a new or freshly rebuilt/reconditioned drivetrain component. I've sent out diffs that come back for warranty a week later and the customer was stupid/honest enough to leave their bald tyres on the car and worn down crown/pinion inside the diff housing.
  • 4 weeks later...
Mine is extremely noisy. Pedestrians will definitely hear it. When cold its fine, drives like a viscous. Its when its warm that it gets savage.
But u wont be sorry with a kaaz, on a track car, on a daily....................not so much
KAAZ FTW.
Question for Bubba how was the nismo as a daily was it noisy like the Kaaz are?.
Cheers,
Dave
It is noisy, more so when cold (it's really, really tight when cold so it skips and clunks). Once warm it slips when it should but you get a kind of dull grinding sort of noise.
Really, it's about how you drive these things.. hold constant throttle round a corner and it's fine. Go round the corner on decel and it will clunk and skip (I have the 2-way), go round the corner with a little bit of gas and it will clunk and skip.. go round the corner with lots of gas and it's super fun happy slide time :D
Personally, I love it and wouldn't want any other diff.. not putting one in the Stag though :P
Thanks Hamish & Bubba I might look into the 1.5way Nismo that's Seems ok not to noisy is what I'm after thanks for the input people if anyone else has an OS giken to compare with that would close the circle of info that I would need to choose for my GTR.
Cheers,
Dave.
I have the Nismo GT LSD Pro 1.5way in my 32 gtr.
A touch chattery when turning and cold but hardly much chatter when warmed up.
Will chatter slightly though when doing a u turn and warm.
Note: it chatters and cluncks a lot more with the run in oil that comes with it (for obvious reasons) and has quitened down since putting in some castrol diff oil.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
