This is driving me nuts.
Only on first start up in the morning a very loud squeal comes from the general area of the belts. It happens whether the a/c is on or off so it is not slippage there.
On start up engine idles around 1000-1100 and the noise is deafening. Its an auto, and when I shift into reverse the revs drop to 8/900 and the noise stops. If I put it back into park the revs go up and the noise starts.
Before I start pulling things to bits has anyone got a clue????
By the time the car is out on the road its all quiet
Just went and started engine six times and it did it each time. Seems to be associated with rpm. BiIk/
Edited by 66yostagea
https://www.sau.com.au/forums/topic/292841-squealing-belts/
First thing I would look at is belt tension, as it's a 5 minute fix.
Then, if all seems well, I'd check for belt wear, as they wear, the peak of each rib in the belt can bottom out in the grooves on the pulley.
The belt relies on the wedging action of the sides of each rib in the belt, not contact with the base of the pulley groove. You then lose the wedging action of the belt; voila! Slippage with a correctly tensioned belt.
Hope this makes sense, Dale
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891618
its friction related, or lack there of. the belts are probably cold in the morning, and once the engine warms up they warm up and grip a little more. also they would stretch or shrink (i would guess stretch) when warm.
if they look old, replace them!
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891646
At a guess, I'd say, first thing in the morning, the belt's less grippy because it's cold, also the load from the alternator is quite high, giving a rev while the alternator is loading the belt could cause the slip.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891648
Dont bother with that Belt Grip sh1t - does nothing!
as mentioned just find what belt needs to be tensioned and nip up the tension on it.
Agreed, belt grip, it actually does work, just covers up an existing issue, I use it from time to time on multi vee belt set ups (up to 15 belts over 6 metres in length) at work, to get to the end of a production run. But we then change them as a matched set. Put the cash towards a new belt.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891664
Hi.
The best way to stop a squealing belt is chalk. Chalk powder is ideal if not get a stick of chalk rub on sandpaper sprinkle the dust on the belt and if you still have a squeal it needs tensioning correctly. You dont need expensive sprays an lubes.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891690
i get a cold start belt squeak most of the time!
asked my mechanic about it and he just said it was common in stageas for cold start squeakage. haha
tightening the belts should get rid of most of it!.. :)
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891733
if tightening the belt doesn't work its time for new ones. belts usually squeak either because they aren't tight enough, or the belt or the pulley is worn to the point where the ridge of the "V" on the belt is touching the valley of the "V" on the pulley, usually its the belt thats worn. the belt shouldn't be that tight that it is so tight it feels solid or with very little play, running them this tight will cause wear on the pulleys and can even flog out the bearings on parts like the A/C compressor, Alternator etc.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891806
So.
I have slackened off the altenator belt a bit. It seemed tight and the pulley grooves look very shiney compared to the others. I'll check in the morning and keep you advised.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4892811
lol yea when i bought mine i had the same issue. on my first service i gave it a tweek up about 6 months ago and still havnt heard a thing. i work with belts all the time and like everyone's sayin its ether not tentioned right or its worn out.
btw try not to take the cheat option with chalk or similar do it right and save future issues.
Edited by fat_stag
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4892981
Fingers crossed. I think it is fixed.
I would have thought the altenator belt was too TIGHT, so I slackened it off a bit: that made it worse! So as Luke suggested I tweaked it up a bit and, voila!, she is OK.
Thanks to all for your input.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4893589
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
