This is driving me nuts.
Only on first start up in the morning a very loud squeal comes from the general area of the belts. It happens whether the a/c is on or off so it is not slippage there.
On start up engine idles around 1000-1100 and the noise is deafening. Its an auto, and when I shift into reverse the revs drop to 8/900 and the noise stops. If I put it back into park the revs go up and the noise starts.
Before I start pulling things to bits has anyone got a clue????
By the time the car is out on the road its all quiet
Just went and started engine six times and it did it each time. Seems to be associated with rpm. BiIk/
Edited by 66yostagea
https://www.sau.com.au/forums/topic/292841-squealing-belts/
First thing I would look at is belt tension, as it's a 5 minute fix.
Then, if all seems well, I'd check for belt wear, as they wear, the peak of each rib in the belt can bottom out in the grooves on the pulley.
The belt relies on the wedging action of the sides of each rib in the belt, not contact with the base of the pulley groove. You then lose the wedging action of the belt; voila! Slippage with a correctly tensioned belt.
Hope this makes sense, Dale
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891618
its friction related, or lack there of. the belts are probably cold in the morning, and once the engine warms up they warm up and grip a little more. also they would stretch or shrink (i would guess stretch) when warm.
if they look old, replace them!
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891646
At a guess, I'd say, first thing in the morning, the belt's less grippy because it's cold, also the load from the alternator is quite high, giving a rev while the alternator is loading the belt could cause the slip.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891648
Dont bother with that Belt Grip sh1t - does nothing!
as mentioned just find what belt needs to be tensioned and nip up the tension on it.
Agreed, belt grip, it actually does work, just covers up an existing issue, I use it from time to time on multi vee belt set ups (up to 15 belts over 6 metres in length) at work, to get to the end of a production run. But we then change them as a matched set. Put the cash towards a new belt.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891664
Hi.
The best way to stop a squealing belt is chalk. Chalk powder is ideal if not get a stick of chalk rub on sandpaper sprinkle the dust on the belt and if you still have a squeal it needs tensioning correctly. You dont need expensive sprays an lubes.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891690
i get a cold start belt squeak most of the time!
asked my mechanic about it and he just said it was common in stageas for cold start squeakage. haha
tightening the belts should get rid of most of it!.. :)
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891733
if tightening the belt doesn't work its time for new ones. belts usually squeak either because they aren't tight enough, or the belt or the pulley is worn to the point where the ridge of the "V" on the belt is touching the valley of the "V" on the pulley, usually its the belt thats worn. the belt shouldn't be that tight that it is so tight it feels solid or with very little play, running them this tight will cause wear on the pulleys and can even flog out the bearings on parts like the A/C compressor, Alternator etc.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4891806
So.
I have slackened off the altenator belt a bit. It seemed tight and the pulley grooves look very shiney compared to the others. I'll check in the morning and keep you advised.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4892811
lol yea when i bought mine i had the same issue. on my first service i gave it a tweek up about 6 months ago and still havnt heard a thing. i work with belts all the time and like everyone's sayin its ether not tentioned right or its worn out.
btw try not to take the cheat option with chalk or similar do it right and save future issues.
Edited by fat_stag
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4892981
Fingers crossed. I think it is fixed.
I would have thought the altenator belt was too TIGHT, so I slackened it off a bit: that made it worse! So as Luke suggested I tweaked it up a bit and, voila!, she is OK.
Thanks to all for your input.
https://www.sau.com.au/forums/topic/292841-squealing-belts/#findComment-4893589
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
