you could use stainless. and braze it. ie swage the stainless pipe up so the ti fits into it and braize/silver solder it.
yeah titanium is a hard and expecive material to weld. often cracks at the weld aswell if its not exacly the same grade too. :S
Where are you located? If you can supply/soarce some titanium pipe and are local i can have it done for you.
I'm in the Trinidad in the Caribbean where Ti pipe is impossible to get, and i could probably count the number of Tig welders on one hand :)
Can any other material be welded to the Ti reliably beside the Stainless?? Mild steel maybe???
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
