F/s 95 Skyline With Heaps Of Mods
FOR SALE MODIFIED SKYLINE
1995 MODEL R33 GTST
Can send the car anywhere in Australia FREE of charge
Car is used but in good condition. Has minor scratches and dents.
Car is in Darwin
Price: 13900.00
Colour: White
Interior colour: Grey/Black
Kilometres: 121000
Transmission: 5 speed Manual
Drive type: Rear
Rego Plate: 913728
Rego Expiry: April 2010
Engine: 6 cylinder Petrol Intercooled Turbo 2.5L
Website: this one and carsales.com.au
Need to sale urgently. Skyline series 1.5 Safe tuned to 240RWKW at 15PSI.
Heaps of mods.
Engine is only 12month old since rebuilt.
Body Kit .
The car is beautiful to drive. Has the power when you need it. Has the stability when required. Just handles great. Have spent far too much on car. Just love it, but have to sell because of other commitments.
Has big turbo and Haltech ECU but is tuned to a safe power level. Has much more power in reserve
Please call for more details: 0407 481755
MODIFICATIONS:
Car modifications:
New wheels and tires all round
Turbo back exhaust
Large 600X300X76 GTR Intercooler 3” inlets
Mechanical rear diff
Hicas lock for rear steering
Front & rear strut braces
Front coil overs
Rear spring & koni shocks
External mount Oil filter
External Oil cooler B&M 500hp
Haltech ECU E11V2 with 3 bar map sensor
Exedy clutch NSK7056HDB
Machined flywheel
New front rotors DBA 4000
All new Endless brake pads
New drive shaft
Xforce dump pipe
2 new rear axle bearings
Xforce high flow cat-Nissan R33
Cold air intake
New battery
Side pillar with boost and oil pressure gauge
Haltech shift light
JVC Head unit with USB input
Alarm and central locking
Engine modifications on RB25DET built 12 month ago but has done very little kays:
Acid cleaned and prepped block
Eagle H-beam con rods
Balanced crank to suit new rods and pistons
ACL forged pistons and rings
Jun oil drive
Nissan N1 Oil pump
ARP crank, big end and head studs
R33 water pump
New tensioners and Nissan belt
All other belts are new Gates
Head built with tomei poncams
Tomei exhaust cam wheel
NGK iridium plugs
Splitfire Coilpacks SF-DIS-005
Hi Energy6.5L Baffled Sump Pro Eliminator
Tomei oil restrictor
Rear oil drain fitted to sump
Bosch 040 550HP fuel pump
Sard adjustable fuel pressure regulator
Upgraded injectors
Turbosmart adjustable boost controller
Turbosmart blow BOV FG-003SS
Garrett GT3071R T3 turbo charger 550hp Dual Ball Bearing with
ceramic coated exhaust housing
Peterson catch can
Just give me a call to get more info. Can send the car anywhere in Australia FREE of charge. Price is negotiable.
Call for further information: 0407 481755 or PM
More pictures on carsales.com
Edited by herbert
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
