It's mainly low speed turning and carpark manoeuvring. It does it intermittently (which is annoying).
As far as I know there are no suspension mods, but the guy I bought it from got it as a mid-life crisis toy and didn't know a thing about the car. The back end looks higher than other r34s I've seen around.
Could it have anything to do with the spacers on the wheels? Or the irritating fact that the front tyres are different?
Many thanks
Could it have anything to do with the spacers on the wheels? Or the irritating fact that the front tyres are different? Many thanks
spacers = Wheel bearings --- ?
Shockys ?-------- mine gave of a load of small funny (not) intermitant noises from knocks to groans at slow /manouvering speeds, had a couple of leaking shockys (1 front 1 rear) put in new all good again.
  • 1 year later...
Old thread dig up.
I'm having the exact same issue, when turning the wheel left.
But before i go out and put new shocks - does it actually solve the issue?
It seems to be getting worse (as in louder) but the issue is still intermittent for low speed left turns/parking.
I've already changed the power steering fluid (Transmax Z), thinking old fluid would be the issue, but it has made no difference.
What else could it be?
  • 3 weeks later...
Now you dig way old post,but that's cool to me,try to check it out your upper control arms,that was a culprit in my R33...i raised the height and changed the upper control arm,all creaking noise gone.Otherwise used to have all the time whenever going over the driveways or speed breakers or hump's...may be help you out so try to check height and upper control arms...
